What QoS markings for CIPC keep-alives?
I have a setup with CIPC at a remote site which loses connectivity to the CUCM and, therefore, unregisters.  CUCM traces show a keep alive timeout when the phone unregisters.  The WAN interface from the site, outbound, has a lot of drops in the Critical (af31) queue.  I suspect that this could be the problem but need to know the markings of the keep-alive packets when it leaves the phone.  What is the default marking of the packets?
This is the switch interface config
switchport access vlan 100
 switchport mode access
 switchport voice vlan 200
 no logging event link-status
 no logging event power-inline-status
 srr-queue bandwidth share 1 40 45 15
 priority-queue out
 no snmp trap link-status
 mls qos trust dscp
 spanning-tree portfast
 spanning-tree guard root
global config:
mls qos srr-queue output dscp-map queue 1 threshold 3 46
mls qos srr-queue output dscp-map queue 2 threshold 3 48 56
mls qos srr-queue output dscp-map queue 3 threshold 1 62
mls qos srr-queue output dscp-map queue 3 threshold 3 24 26 28 30 40 63
mls qos srr-queue output dscp-map queue 4 threshold 3 32 34 36 38
mls qos queue-set output 1 buffers 15 30 35 20
mls qos
The other switches have the 'mls qos trust dscp' on their interfaces to the WAN router, so it looks like the markings stay the same to the router.
kulsinghdeep
I was thinking about the same problem and I got a nice documentation on it... hope this will help you out.
TRUSTED RELAY POINT (TRP) AND QOS FOR SOFTPHONES...
http://www.netcraftsmen.com/trusted-relay-point-trp-and-qos-for-softphones/
