What "Call State" do I configure for Abbreviated Dial?
kbeaton
What "call state" do I edit when using Abbreviated Dial on a 7900 series phone?
In testing, I press the speed dial number I've already setup, the soft keys at the bottom are Dial, Backward (<<), AbbrDial and Cancel.
I don't see those soft keys in any of the Call States
On Hook
Connected
On Hold
Ring
Off Hook
Connected Transfer
Digits after First
Connected Conference
Ring Out
Off hook with Feature
Remote in Use
Connected No Feature
Kelvin
luis_cordova
Hi @kbeaton ,
Maybe this link can give you some help:
https://www.tek-tips.com/viewthread.cfm?qid=1632236
Are you trying to remove the AbbrDial softkey from template, or add it?
Also, what version of CUCM are you using (some of the default softkey templates changed with different versions)? And which softkey template are you looking at?
If you press a regular speed dial the call state will be Digits After First until the target rings, and then it will be Ring Out until the target picks up, and then it will be Connected.
Maren
