What's the username and passwod of ata 190 devices
i want to login phone adapter configuration utility of this device, cisco and cisco can login ,but can't chang the set.
8 Replies 8
Leo Laohoo
cisco/cisco
thank you friend,do you know how to disable web ui or http of this device
What is the intention of locking up the ATA?
If the ATA is loaded with Enterprise firmware, it can only receive configurations from CUCM.  Anyone who browsing the IP address of the ATA will only get read-only access.
If the ATA is loaded with 3PCC/MPP firmware, how is anyone expected to configure, troubleshoot and monitor the ATA if web access is disabled?
thank you for your reply,because my company do not allow to enable port 80 or http,port 443 is ok,
HTTP can be disabled in CUCM.
thank you
User can access the ATA 190 web page and perform limited configuration. Two access modes exist: Admin mode and User mode.
  • The default username/password for Admin mode is admin/admin.
  • The default username/password for User mode is cisco/cisco.
Response Signature
thank you
friend, do you know how to disable web ui or http port 80 of this device
