What will occur when phone lost connection in SRST mode
eliba0001
I Have 3 phones registered in SRST mode  ( wan is down )
What will occur if the phones got power cycle  ?
Did the phones should get registered again ?
from what I see the phones not registered and didnot get IP address from the DHCP .
Eli
Configure  a local DHCP with option 150  as your HQ.
Response Signature
Can these phones reach the DHCP server?
Response Signature
I configured DHCP in SRST , and lines goes  registered and that its ok ...
 and 3 Dial-peer was rebuilt in SRST .
The issue is while one of the phones was reset  and registered again , the srst built a new Dial-peer with the same Number .
so we got a duplicate dial-peer with the same number registered
please see Registered status :
Router# show sip-ua status registrar
Line destination         expires(sec) contact
transport call-id
peer
3029991 10.2.30.108               388             10.2.30.108
TLS 00120014-4ae40064-f1a3e9fe-8d301072@10.2.30.1
40004
3029993 10.2.30.103               382              10.2.30.103
TLS 001bd433-1c840052-655cd596-4e992eed@10.2.30.1
40011
3029982 10.2.30.106              406               10.2.30.106
TLS 001d452c-dbba0056-0481d321-1f3f848d@10.2.30.1
40001
3029982 10.2.30.106                0                   10.2.30.106
40001
As you see the last line show expired="0"
In this time while the WAN is back the all Registered record should be cleared  from the SRST
BUT the last line still exist
40001
How can I cleared this record Line ?
Eli
eliba0001
DHCP was configured in SRST
Phones got Registration and that its ok .
I have a scenario while IN SRST mode one of the phone lost connection and tried to registered again
The Phone was registered ok but while running --> show sip-ua status registrar
I have got duplicate number and Dial-peer :
transport call-id
peer
40004
40011
40001
3029982 10.2.30.106 0 10.2.30.106  <======== Expired ==0
40001
As you see we got Duplicate Dial-peer and of them with Expired=0
then the WAN is back .. In that time all Dial-peer should removed from this table
But the one with Expired=0 still exist
How to avoid this situation ? How can we remove this line
Eli
