Where can I find list of SEP<MAC>.cnf.xml files in CUCM?
Where can i find list of SEP<MAC>.cnf.xml files in CUCM.
I have tried tftp <CUCMIP> get SEP<MAC>.cnf.xml in CMD. but this gives only the output of that MAC address.
is there any option to find  the list of all SEP<MAC>.cnf.xml file in CUCM?
thanks  in advance.
16 Replies 16
hi,
TFTP will be disabled in windows by default, you need to enable it.
check the CUCM is reachable from you PC
check the IP phone is registered with CUCM
if you are getting as "Transfer successful"  in CMD, the file will be stored in the Cdrive  >User  >  SEP.cnf.xml.
I allready enable the Tftp manually
I also try TFTPD32 with the GUI interface to download the xml.
I also try in CLI in the CUCM
the phone is register with CUCM
I add SEP"MAC".cnf.xml
it cant find it.. not sure why..
