Where do we set the RTP port range in CUCM?
techToddler
Hello Friends,
I request your help in understanding the RTP port concept.
   m=audio 25268 RTP/AVP 18 0 8 101
I took this log from CUCM and wanted to know how this port is assigned dynamically or where is it defined?
Is there a place that we can look.
Sanjay.
Jitender Bhandari
Hi Sanjay,
RTP port is dynamically generated by endpoint, from the range 16384 - 32767 UDP
JB
Thank you.
Sanjay
Jaime Valencia
For SIP endpoints, you can configure the range in the SIP profile.
java
if this helps, please rate
Hi Jaime, what is the smallest range you can use?
I want to restrict traffic with ACL and have the smallest RTP range allowed only.
