Which Card Required
Sabby0115
Hi Friends
I have 8 pstn lines and hav 2811 router, 3750 Poe, I want to configure ip telephone system, how can i route the pstn lines to
router and How many cards do i need? if it us FXO Card. Can 2811 Support 2 FXO 4 Port (Two VIC2- 4FXO so i can get 8 connections);
Thanks in advance
Aman Soi
Hi ,
You can refer the link for VIC/FXO  cards support on ISR series ?
http://www.cisco.com/c/en/us/support/docs/routers/2600-series-multiservice-platforms/5111-voice-comp-matrix.html
regds,
aman
Dragan Ilic
Level 4
Level 4
You have 4xHWIC slots on that router which supports VIC cards also. So yes - you can put 2xVIC2-4FXO and connect your 8 PSTN lines with it. Just remember to check if you have enough DSP resources for this and adequate IOS on platform which supports voice ;)
BR,
Dragan
HTH,
Dragan
