which IOS resolve this %SIP-3-UNSUPPORTED and %SYS-INPUTQ
iantra123
Level 3
Level 3
We experience some problem about IP-to IP Gateway.
We use Cisco 2811 ISR using MGCP, and SIP IP-IPGw.
The router have VWIC2-2FMT-E1 (in MGCP) and use HWIC-2FE
If we use the IOS c2800nm-advipservicesk9-mz.124-11.T2.bin then the HWIC-2FE is not supported
If we use c2800nm-advipservicesk9-mz.124-24.T2.bin then we have the bug %SYS-2-INPUTQ.
When we check the bug toolkit, then it ask to upgrade the IOS
When upgrading the IOS to c2800nm-advipservicesk9-mz.124-24.T5.bin (this is the last of the T version) then we have the  bug %SIP-3-UNSUPPORTED.
And the Error decoder ask us to upgrade once again.
So which IOS support these features, and without these bug on cisco 2811
MGCP
IP-toIP GW (SIP)
HWIC-2FE
MFTE1
we already check the c2800nm-adventerprisek9_ivs_li-mz.124-24.T5.bin, but it doesn(t support MGCP.
Antra
Vinay Kumar Dharmaraj
Hi Antra,
Your current IOS version supports all the features you looking for,
HWIC-2FE Support on 2811
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd80581fe6_ps5855_Products_Data_Sheet.html
MFT-E1
http://www.cisco.com/en/US/prod/collateral/routers/ps274/product_data_sheet09186a0080091b9c_ps259_Products_Data_Sheet.html
MGCP and SIP Support (Cisco Feature Navigator),
http://tools.cisco.com/ITDIT/CFN/Dispatch?act=rlsSelect&task=search&searchby=software
With respect to "%SIP-3-UNSUPPORTED" error, you typically see this message when you run unsupported features like DO-DO Video call, unsupported payload / packatization, etc.
It is difficult to say anything without the complete error message or the Bug-ID. Could you please copy the complete error message or the Bug-ID ?
Vinay
paolo bevilacqua
You can use, for example, 15.0(1)M6.
The problem was not a bug but the ptime value.
The ptime value should between 5 to 20 but the ptime value in the other side is more than supported by cisco.
regards,
Antra
