Which IOS version is working properly for CME 8.6 using the FAC (Forced Authorization Code) feature?
omarcruz1
Hi everybody, I deployed a Router ISR 3945e with IOS 15.1(4)M3 for CME 8.6. I am facing problems with the FAC feature. Reloading Router, it lost a line of Router configuration which makes to send user a tone to restrict calls. So that, without that line, users can dial any number without the FAC restriction tone. I would like to know if you guys have been working with an IOS version that doesnt have this issue?
the line that is lost is "lpcor outgoing <lpcor-group>"
thanks in advance
8 Replies 8
paolo bevilacqua
Update IOS.
I know I must update IOS, but I wanted to know if someone, in the cisco community, had tryed an IOS version that works properly with FAC without having same issue.
hope you can help me guys
have a great day!!!
I have an IOS 15.1(4)M4 and have the same problem, which ios is the correct?
I think you have to enable AAA ,please check the below link.
https://supportforums.cisco.com/thread/2089663
Thank you
please rate if this will help
I have the aaa enable
hello
did you check the link which i shared .
thank you
Anas Abueideh
Level 9
Level 9
kindly find the below compatability matrix for CME vs IOS
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
if you miss this command, try to upgrade IOS. I  configured FAC for CME but I don't remember what was the version. mostly it is 8.6
regards
Anas
Anas Abueideh
Level 9
Level 9
Hi Omar,
I use the below config for Fac and it was working
aaa new-model
aaa authentication login default local
aaa authentication login h323 local
aaa authorization exec h323 local
aaa authorization network h323 local
application
package auth
  param passwd-prompt flash:enter_pin.au
  param term-digit #
  param abort-digit *
  param user-prompt flash:enter_account.au
  param max-digits 32
service clid_authen_collect
  param uid-len 3
  param pin-len 5
username 304 password 0 15000
username 304 autocommand exit
dial-peer cor custom
name fac-int
name user-fac
dial-peer cor list fac-int
member fac-int
dial-peer cor list user-fac
member user-fac
dial-peer voice 400 voip
corlist incoming fac-int
corlist outgoing user-fac
destination-pattern 900T
session target ipv4:10.1.1.1
incoming called-number 900T
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 69 pots
corlist outgoing fac-int
translation-profile outgoing DiscardDigit9
preference 3
port 0/2/1
forward-digits all
no sip-register
ephone-dn  30 octo-line
number 304 no-reg primary
label 304
description user2
name user2
corlist incoming user-fac
Anas
please rate if it is helfpul
