06-15-2011 11:28 AM - edited 03-16-2019 05:28 AM
please let me which poe switch working cisco 7960 ip phone is it ok with catalyst 2960 pc-l
Solved! Go to Solution.
06-15-2011 11:46 AM
Hi Shashi,
Yes, you would be good to go with that model as the 7960's use
Cisco Pre-standard PoE
The Cisco Catalyst 2960 Series with PoE allows connectivity to Ethernet powered devices including Cisco IP phones, wireless access points and video cameras. Cisco Catalyst 2960 Series with PoE models support Cisco pre-standard PoE and are IEEE 802.3af-compliant. The Cisco Catalyst 2960-24PC-L can support 24 simultaneous full-powered PoE ports at 15.4W. The Cisco Catalyst 2960-24LT-L has 24 10/100 Mbps ports with 8 simultaneous full-powered PoE ports at 15.4W.
Cheers!
Rob
06-15-2011 03:05 PM
No problem with that setup. I've got 2960 PCL and 2960 LANLITE with 7940/7960/7970 phones. No issues.
06-15-2011 11:46 AM
Hi Shashi,
Cheers!
Rob
06-15-2011 03:05 PM
06-16-2011 02:48 PM
Thanks for the ratings.
