ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Beginner
why CUBE is not transparently sending in incoming ringing(180) with SDP to an outgoing ringing(180) with SDP?
Everyone's tags (5)
9 REPLIES 9
Highlighted
Hall of Fame Master
Include traces and config to prove your point.
Highlighted
Beginner
below is an output of debug ccsip messages that proves it
Received:
INVITE sip:2188723@10.3.3.3:5060 SIP/2.0
Via: SIP/2.0/UDP 10.11.1.2:5060;branch=z9hG4bK1D7B3
Remote-Party-ID: <7777>;party=calling;screen=no;privacy=off
To: <2188723>
Date: Fri, 01 Mar 2002 01:01:01 GMT
Call-ID: A1DD5368-2BE611D6-80639ED3-CD2E991A@10.11.1.2
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 2672116199-736498134-2153684691-3442383130
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1014944461
Contact: <7777>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 206
v=0
o=CiscoSystemsSIP-GW-UserAgent 3874 1391 IN IP4 10.11
AAA-FW(config.1.2
s=SIP Call
c=IN IP4 10.11.1.2
t=0 0
m=audio 16520 RTP/AVP 8 19
c=IN IP4 10.11.1.2
a=rtpmap:8 PCMA/8000
a=rtpmap:19 CN/8000
a=ptime:20
2w1d: //78482/9F4541E7805E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <2188723>
Date: Tue, 31 Jul 2012 11:04:42 GMT
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
2w1d: //78483/9F4541E7805E/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE tel:2188723 SIP/2.0
Via: SIP/2.0/UDP 10.100.1.23:5060;branch=z9hG4bK169EB1FF5
To: <08723>
Call-ID: 5D425A6B-DA3611E1-84B4F1AA-49412B66@10.100.1.23
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2672116199-0736498134-2153684691-3442383130
CSeq: 101 INVITE
Timestamp: 1343732682
Contact: <10.100.1.23:5060>
Expires: 180
Max-Forwards: 69
Content-Length: 194
v=0
o=CiscoSystemsSIP-GW-UserAgent 4138 4325 IN IP4 10.100.1.23
s=SIP Call
c=IN IP4 10.100.1.23
t=0 0
m=audio 19334 RTP/AVP 8
a=ptime:20
Received:
SIP/2.0 100 Trying
To: <08723>
CSeq: 101 INVITE
Content-Length: 0
AAA-FW(config)#
2w1d: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
hello
Received:
hello
Received:
hello
Received:
SIP/2.0 180 Ringing
To: <08723>;tag=kvzn899v-CC-1004
CSeq: 101 INVITE
Allow: INVITE,ACK,BYE,CANCEL,UPDATE,INFO,PRACK,NOTIFY,REFER,SUBSCRIBE,OPTIONS,MESSAGE
Require: 100rel
Contact: <10.100.10.34:5060>
P-Early-Media: sendonly
P-Charging-Vector: icid-value=mgcf--20120731130056-100425316;term-ioi=mgcf.home.net
RSeq: 1
Content-Length: 155
v=0
o=ug 1073776664 1073776665 IN IP4 10.100.10.34
s=SipCall
c=IN IP4 10.100.11.1
AAA-FW(config29
t=0 0
m=audio 29244 RTP/AVP 8
a=ptime:20
a=sendrecv
Sent:
PRACK sip:10.100.10.34:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.100.1.23:5060;branch=z9hG4bK169EC147C
CSeq: 102 PRACK
RAck: 1 101 INVITE
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 183 Session Progress
To: <2188723>;tag=4DE67B14-2047
CSeq: 101 INVITE
Require: 100rel
RSeq: 8487
Remote-Party-ID: <2188723>;party=called;screen=no;privacy=off
Contact: <2188723>
Supported: sdp-anat
Content-Length: 188
v=0
o=CiscoSystemsSIP-GW-UserAgent 6707 5274 IN IP4 10.3.3.3
s=SIP Call
c=IN IP4 10.3.3.3
t=0 0
m=audio 17260 RTP/AVP 8
c=IN IP4 10.3.3.3
a=ptime:20
Received:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
Received:
PRACK sip:2188723@10.3.3.3:5060 SIP/2.0
Via: SIP/2.0/UDP 10.11.1.2:5060;branch=z9hG4bK1E2E0
CSeq: 102 PRACK
RAck: 8487 101 INVITE
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 200 OK
Date: Tue, 31 Jul 2012 11:04:47 GMT
CSeq: 102 PRACK
Content-Length: 0
AAA-FW(config)#
Received:
hello
Highlighted
Hall of Fame Master
Both received and sent INVITE appears to have an SDP:
Content-Length: 206
v=0
AAA-FW(config.1.2
s=SIP Call
c=IN IP4 10.11.1.2
t=0 0
c=IN IP4 10.11.1.2
a=rtpmap:19 CN/8000
a=ptime:20
and
Content-Length: 194
v=0
s=SIP Call
t=0 0
a=ptime:20
Highlighted
Hall of Fame Master
Incoming '180 ringing' goes outgoing as '183 session progress', both have SDP, in bold below:
Received:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Require: 100rel
RSeq: 1
Content-Length: 155
v=0
s=SipCall
AAA-FW(config29
t=0 0
a=ptime:20
a=sendrecv
Sent:
CSeq: 102 PRACK
RAck: 1 101 INVITE
Max-Forwards: 70
Content-Length: 0
Sent:
CSeq: 101 INVITE
Require: 100rel
RSeq: 8487
Contact: <2188723>
Supported: sdp-anat
Content-Length: 188
v=0
s=SIP Call
c=IN IP4 10.3.3.3
t=0 0
c=IN IP4 10.3.3.3
a=ptime:20
Highlighted
Beginner
yes clearly both have SDP, but the question was why CUBE does not allow for sip 180 message transparency instead of converting it to 183 ? as IETF SIP standards do not mandate this behavior
Highlighted
Hall of Fame Master
I don't dare to give an answer myself, begin SIP and the Cisco implementation, the confusing mess that it is.
However, with SDP present, both messages are pretty much equivalent.
Highlighted
Beginner
not exactly the absence of 180 message can cause problems in some situations, so i hope some one can answer this question
Highlighted
Hall of Fame Master
Re: why CUBE is not transparently sending in incoming ringing(18
I agree they are not the same thing, on the other hand I think that converting 180 to 183 will not prevent CUBE from forwarding the ringback media (if present at all) or the SIP provider from receiving it, that I suspect is the reason why you're asking this.
Highlighted
VIP Mentor
Frisko,
You have been on this for a while. I guess this is the second post you have submitted on this issue. Why dont you open a TAC case wtih Cisco and hopefully they can answer your question. Personally I have not seen CUBE sending 180 with SDP. I know that CUCM does not send 180 with SDP it only sends 183 with SDP. Maybe this is the case with CUBE. Open a TAC case and hopefully you can share your findings.
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
