Why my routers says I have two voice cards (DSP)
Hi all,
I just wanted to ask you, why my router has 2 voice cards, in the show run, look at my configuration.
voice-card 0
dspfarm
dsp services dspfarm
voice-card 1
voice rtp send-recv
voice service voip
ip address trusted list
  ipv4 10.2.50.5
  ipv4 10.0.0.0 255.0.0.0
  ipv4 10.2.50.9
h323
modem passthrough nse codec g711ulaw
But, when I put, show inventory, it says that the router only have one card.
#show inv
NAME: "CISCO3945-CHASSIS", DESCR: "CISCO3945-CHASSIS"
PID: CISCO3945-CHASSIS , VID: V02, SN: FTX
NAME: "Cisco Services Performance Engine 250 for Cisco 3900 ISR on Slot 0", DESCR: "Cisco Services Performance Engine 250 for Cisco 3900 ISR"
PID: C3900-SPE250/K9   , VID: V04 , SN: FOC
NAME: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-2MFT-T1/E1  , VID: V01 , SN: FOC
NAME: "3rd generation four port FXS DID voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "3rd generation four port FXS DID voice interface daughtercard"
PID: VIC3-4FXS/DID     , VID: V03 , SN: FOC
NAME: "PVDM3 DSP DIMM with 192 Channels on Slot 0 SubSlot 3", DESCR: "PVDM3 DSP DIMM with 192 Channels"
PID: PVDM3-192         , VID: V01 , SN: FOC
NAME: "Network Module Adapter for SM Slot on Slot 1", DESCR: "Network Module Adapter for SM Slot"
PID: SM-NM-ADPTR       , VID: V01, SN: FOC
NAME: "Enhanced High Density Voice Network Module on Slot 1", DESCR: "Enhanced High Density Voice Network Module"
PID: NM-HD-2VE         , VID: V01 , SN: FOC
NAME: "Services Module with Services Ready Engine on Slot 2", DESCR: "Services Module with Services Ready Engine"
PID: SM-SRE-910-K9     , VID: V01 , SN: FOC
NAME: "C3900 AC Power Supply 1", DESCR: "C3900 AC Power Supply 1"
PID: PWR-3900-AC       , VID: V03 , SN: QCS
¿am I wasting DSP resources by not using that "phantom" card?
I am using that DSP for the following configuration.
2 E1 DS0 voice link configuration (60) channels.
dspfarm profile 1 transcode
codec g729r8
codec g729br8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 8
associate application SCCP
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
What I meant to ask you, is...
do I only have 1 DSP card?
do that DSP card is the only card I need to perfectly fit my configuration?
I've read about DSP, but I only know fundamentals. I do not know very much the meaning on my router configuration. I just had a router with a similar configuration, copy/pasted it, and then in works.
Chris Deren
Blank NM-HD-2VE card in slot 1 via an adapter is what creates the dsp voice card, though there are not PVDMs in it, so no need to worry about it.
HTH,
Chris
5 Replies 5
Anthony Holloway
Your High Density Voice Card has PVDM's on it.  They are most likely PVDM2's and you'll have some limitations using them in the same pool as your PVDM3's.
EDIT: Read through your inventory too fast.  If you had PVDMs on your module, they woulod be PVDM2's.
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
islam.kamal
Level 10
Level 10
YOu only have one DSP , PVDM3-192  which is on slot0,  Kindly find the below link.
http://www.cisco.com/en/US/prod/collateral/modules/ps3115/data_sheet_c78-553971.html
Thank you
please rate if this will help you
Chris Deren
HTH,
Chris
Ayodeji Okanlawon
On the DSP side of things, you have a PVDM3-192. This PVDM has a total of 5 dsps in it. It is a combination of a single PVDM3-128 and PVDM3-64.
Each PVDM3-128 has 3 dsps and each PVDM3-64 has 2 dsps..Hence giving you a total of 5 dsps..
You can read more on PVDM2 and PVDM3 credit allocations here..
https://supportforums.cisco.com/docs/DOC-29164
Attached is a Q and A that helps you to understand Cisco PVDM better
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hi Cris, I didn't realize I had a Voice Card withput DSP, I didnt realice a NM could create a "Voice Card conf" even without a PVDM on it.
Well that was what I understood, also i'll check the links posted on this thread.
Thank you all of you for your time, your help is very useful.
regards.
