08-28-2019 05:58 AM
Hi - for years I have been told that Cat5e cabling is required for Cisco Unified Communications phones. Is there a technical issue requiring Cat5e or will Cat5 (which does support PWe have a site that is a mix of Cat5 and Cat5e cables going from patch panel to RJ45 jacks. Will there be issues using the Cat5 cabling in running/powering the phones? Thanks!
08-28-2019 06:13 AM - edited 08-28-2019 06:16 AM
08-28-2019 08:01 AM
08-28-2019 09:16 AM
Hi @Gail_GMG11566 ,
I'm glad to help you.
Remember to mark the correct answers as solved, because that helps other users with similar questions
