cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
Will Cat5 cabling work with Cisco 8800 series phones?
Gail_GMG11566
Hi - for years I have been told that Cat5e cabling is required for Cisco Unified Communications phones.  Is there a technical issue requiring Cat5e or will Cat5 (which does support PWe have a site that is a mix of Cat5 and Cat5e cables going from patch panel to RJ45 jacks.  Will there be issues using the Cat5 cabling in running/powering the phones?  Thanks!
3 RESPOSTAS 3
Thank you @luis_cordova
Hi @Gail_GMG11566 ,
I'm glad to help you.
Remember to mark the correct answers as solved, because that helps other users with similar questions
