windows 2008 on UCS 220 M3
Hi ,
We are trying to install windows 2008 on UCS 220 M3 , and we do not see any harddisk to install..
How can achieve this ?
Reagards,
Purna
2 Accepted Solutions
Anas Abueideh
Level 9
Level 9
Hi Purna,
you need to configure the RAID to see the HDD. you need to enter the CIMC and web bios to acheive that
Anas
please rate all helpful posts
6 Replies 6
Jaime Valencia
Those servers are meant for virtualization, you install any OS over the hypervisor, not on the bare metal.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Anas Abueideh
Level 9
Level 9
Hi Purna,
Anas
Hi ,
I have created the RAID , and downloaded the following and installed the windows 2008 on UCS 220 M3 ,
http://software.cisco.com/download/release.html?mdfid=284296253&softwareid=283853158&release=1.4%286d%29
the only problem now letf is the network driver is no there in the drivers ios..all other drivers are there....
anyway that we can get the network driver for windows 2008 on UCS 220 M3 ?
Purna
Hi ,
Thanks for the info..we have removed the server,opened the cover ....checked for the Network chipset (intel i350 am2 )
and downloaded the windows 2008 driver from the intel site..it is working now..
thanks
for the support..
purna
Hi Purna,
it is a good news that you get your server work.
thanks for the rating
regards
Anas
