Windows 2008 Server Co-residency BE6000/BE7000/TRCs/Specs-Based.
Joey De Wiele
Hey,
I'm trying to figure out where I can run a Windows 2008 R2 server:
It would be nice if this was corralled into a single location.
Thanks for any answers.
Jaime Valencia
If you run 6K/7k over HYP or FND license, then yes, the above link applies to both. Not sure if you can also buy either license with TRC or spec-based TRC, if so, then they also fall under the guidelines from the link.
If you run any of the above options over VMware std, ent, or ent+ license, general co-res guidelines from virtualization wiki apply.
java
if this helps, please rate
