Windows 7 64-bit support
ca.sanchez
I would like to know if Cisco has given any information about new versions of Cisco IP Communicator and Cisco Unified Video Advantage which can be supported natively on computers running Windows 7 64-bit edition.
I remember that Cisco IP Communicator had an estimated release date around the last quarter of 2010.
Any help will be appreciated, I am not sure if I should contact Cisco´s TAC directly...
Our answers here are limited to what is publicly documented. I suggest you reach out to your Cisco AM or SE who can get you updated information.
Jaime Valencia
Cisco Unified Communications Support for  Microsoft Windows 7
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6789/ps7046/ps7282/product_bulletin_c25-563280_ps427_Products_Bulletin.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks for the quick response...
That is the same information I had previously, the problem is it says IP Comm 8.5 for Q4 2010 and Video Advantage is yet to be decided... I am trying to get an update on both dates...
That is exactly what I did... They said it should be ready around the end of the first half of the year... Thanks for your help
