Without "9" prefix before FAX number
Yangjp715
Level 2
Level 2
Hi there,
I'm configuring a VG204XM for a new branch. The customer required the fax number here should  have a hotline "9" dialed before it, so anyone dialing out does not have to enter a "9" before their FAX numbers, it is only for FAX, other users will have to dial 9 if they want dial out. Is there anyone who can help me with that?
Thanks in advance.
Eric
In which case you can use CSS and Partitions.
devils_advocate
Level 7
Level 7
Are you using CME or CUCM?
Thanks for the reply, it is CUCM 9.1. The new branch only has VG204xm using SCCP.
You mean i can create route pattern or called party tranformation pattern to get is? Thanks.
