04-04-2013 02:43 PM - edited 03-16-2019 04:37 PM
Well when we have a caller call our incoming DID it works just fine, and when a extension is dialed manually or through the UM AA, it goes back to VM if they are not available right?
Well when they leave a voicemail, it emails them and is on the system, but it does not activate our MWI light on the phones.
We run CME 8.6 and have tried inputting all the relevant commands, but to no avail, so we were trying to see if there was settings or if anyone could be of help.
I have attached current config.
04-04-2013 03:46 PM
What version of Exchange UM are you using? Exchange 2007 never supported MWI and you needed a 3rd party solution. With 2010 it should work, though I have never done it with CME.
Chris
04-04-2013 05:35 PM
Exchange 2013
04-04-2013 08:51 PM
Getting this error in Exchange:
The Microsoft Exchange Unified Messaging service on the Mailbox server failed to deliver the MWI notification '1/0 (unread/read)' for the UM-enabled mailbox 'Mercado, Sir Frederick LTG CS, USR(faeb7e87-53ef-48d5-8126-18272b475400)' associated with UM extension '1001'. Until this problem is corrected, the MWI state for this user may be out of sync. Additional information:
There are no more targets available to send an MWI message for user Mercado, Sir Frederick LTG CS, USR.
Server CME Router failed with 481 Call Leg/Transaction Does Not Exist
04-05-2013 10:54 AM
bump? anyone with good info?
04-05-2013 07:27 PM
What type of phone is associated with the user(s)...IP phone, analog (FXS)?
04-05-2013 08:38 PM
IP phones all 7940s.
04-07-2013 03:26 PM
Anyone?
04-07-2013 03:53 PM
HI
please check the below
1-
Here are the steps to delete and recreate the Voice Mail search folder to fix MWI:
2- Check that
MSExchangeMailboxAssistants.exe service is working
please find the below link also
http://technet.microsoft.com/en-us/library/dd297995(v=exchg.150).aspx
Thank you
please rate if this will help
04-07-2013 05:46 PM
I made sure MWI is checked in link.
I tried deleting and re-creating....no go. I assume its a config issue at this point, as I am able to access VM and the AA from exchange over port 5065.
04-12-2013 08:08 AM
Anyone can help on this? There has to be someone experienced with setting up 2013 with CME. Even a sample config of their router would be great to ensure proper settings
11-29-2013 07:45 AM
We're also having MWI issues when moving from Exchange 2010 to Exchange 2013. We're seeing the same error from the Exchange side which, to me, indicates Exchange is trying to send MWI. I'm wondering if the Cisco side (call manager 9.1 in our case) is rejecting the messaging because it's not expecting communication from the address sending it. I think this thread explains it well: https://supportforums.cisco.com/message/4054488#4054488
03-11-2014 08:00 AM
I had this same problem with Exchange 2013 and CME. After taking a packet capture on the Exchange server I noticed that the SIP NOTIFY from Exchange to teh CME router was showing the IP of CME in both the TO and FROM fields.
I changed the mwi configuration in the sip-ua section to point to the IP of CME as shown below and MWI started working
mwi-server ipv4:192.168.0.9 expires 3600 port 5060 transport tcp unsolicited (pointed at exchange)
mwi-server ipv4:192.168.0.254 expires 3600 port 5060 transport tcp unsolicited(pointed at CME)
