06-03-2011 08:24 AM - edited 03-16-2019 05:17 AM
I am trying to change a uk geo number into an 0870XXXXXXX number so when the geo number makes a call it comes up on called users phone , but i cant for the life of me figure out how to do this.
Is this done on the Cube or the CUCM (7.0)
Any help would be appreciated
06-05-2011 09:34 PM
Hi Nathan,
You can do this on the CUCM using the calling and called party transformation. What I cannot understand is that do you want to do this fir a single number or you want for a group of numbers ??
Mudit
06-06-2011 12:34 AM
Hi Mudit,
I only want do do this for 2 different numbers.
for e.g
123456789 to show 987654321 when that phone dials out.
Does that make sense, Inbound this isn't an issue just outbound.
06-06-2011 12:51 AM
Hi Nathan,
you can do either on CUCM or CUBE
On CUbe you can do a voice-translation rule 1
rule 1 /^123456789$/ /987654321/ ---------------------->whenever it will see number123456789 it will translate to 987654321
then create a voice-translation profile change_ani
translate calling 1--------------------------------------------------->this will translate the caling number according to the rule 1
and apply that voice-translation profile on say inbound dial-peer dial-peer
dial-peer voice 1 voip
translation-profile outgoing change_ani --------------> this will change the calling number for the outbound call accoridng to the voice translation profile
PS: Rate if you find the information useful.
sumit
06-06-2011 12:53 AM
Hi Sumit,
How is this done on the CUCM?
I will rate when i have finished with this issue
06-06-2011 01:23 AM
Hi Nathan,
If the translation is done only for 1 number then you can goto ->
ccm -> call routing -> Tranformation Pattern -> Called Party Transformation.
So, before the call hits any route Pattern / Trunk / Route List, the number can be transformed.
If you need to do it for all the numbers then you can create a route list / route pattern and if you scroll down, you will find called and calling transformation.
Mudit
06-06-2011 01:54 AM
So If you want to change only for 2 numbers then
What you can do is you can create translation patterns which will be matched before matching route patterns
Say your first phone is 123456 and assign a CSS A and create a translation pattern say 9.! and put that in partition A
and create calling party transformation in Translation pattern.This has changed your calling party for this phone before matching Route pattern
Second phone is 456890 and assign a CSS B and create a translation pattern say 9.! and put that in partition B
and create calling party transformation in this Translation pattern .This has changed your calling party for Second phone
before matching route pattern.
CSSA contains PT A and CSS B contain PT B
Now assign the CSS of both translation pattern the same CSS which you assign for all the other phones apart from 2 phones which inturn will match the Route pattern
Since Its a long and a bit complicated procedure thats why i advised you to create a voice translation rule on the gateway which simplifes the job .
Rest is up to you.
sumit
06-06-2011 02:08 AM
Hi Sumit,
Thanks for you update, I think i will try what you suggested configuration on the gateway first.
Thanks Mudit
06-06-2011 02:33 AM
Hi Sumit,
I have tried below and it did not work?
voice translation-rule 17
rule 1 /^0669$/ /0870863XXXX/
translate calling 17
dial-peer voice 0669 voip
Any idea's?
06-06-2011 02:36 AM
rule 1 /^0669$/ /0870863XXXX/---->will never work
you cannot have a wild card on the second part of it
sumit
06-06-2011 02:38 AM
so this needs to be
rule 1 /0669/ /0870863XXXX/ ??????
I do know final 4 digits of the 0870 number.
0669 - is the DN
06-06-2011 02:45 AM
it needs to be
HQ-RTR(config)#voice translation-rule 17
HQ-RTR(cfg-translation-rule)#rule 1 /^0669$/ /0870863\0/
HQ-RTR(cfg-translation-rule)#exit
you can check which number is being translated to what.
HQ-RTR#test voice tran
HQ-RTR#test voice translation-rule 1 0669
Error: Rule set 1 not found
HQ-RTR#test voice translation-rule 17 0669
Matched with rule 1
Original number: 0669 Translated number: 08708630669
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
it will change the number 0669 to 08708630669.I guess thats what your requirement is right ????
06-06-2011 02:49 AM
no it needs to be 0002.
but when i tested it to my mobile it still showed the geo number
06-06-2011 02:56 AM
Hi Nathan,
Can you please answer the questions below
1 ) What is your extesion to which your Ip phone is regsitered with call manager
2) what is the number you want to be displayed on your mobile
3) Have you chcked if its matching the correct incoming dial-peer where voice translation profile is bing appplied
4) Please check debug voip ccai inout to see whats the number it is translating to
I think there is some misconfiguration .
sumit
06-06-2011 03:07 AM
1 ) What is your extesion to which your Ip phone is regsitered with call manager - 0669
2) what is the number you want to be displayed on your mobile - 08708630002
3) Have you chcked if its matching the correct incoming dial-peer where voice translation profile is bing appplied - How do i do this?
4) Please check debug voip ccai inout to see whats the number it is translating to - All there seems to be is xxxxxxxxxx
