Wondering if you could help me please
Nathan Hardman
I am trying to change a uk geo number into an 0870XXXXXXX number so when the geo number makes a call it comes up on called users phone , but i cant for the life of me figure out how to do this.
Is this done on the Cube or the CUCM (7.0)
Any help would be appreciated
31 Replies 31
ok create th voice translation-rule
for this
Q-RTR(config)#voice translation-rule 17
HQ-RTR(cfg-translation-rule)#rule 1 /^0669$/ /08708630002/
HQ-RTR(cfg-translation-rule)#exit
voice-translation profile change_ani
translate calling 17
dial-peer voice 0669 voip
translation-profile outgoing change_ani
please send me the running config and debug voip ccapi inout.
Thanks.
sumit
Hi Sumit,
i have added the ccapi inout, but my line manager has denied me access to send you the running config, but i can assist you in any questions.
Jun  6 10:03:51.279: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x471599EC, Interface Type=9, Destination=0.0.0.0, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Jun  6 10:03:51.279: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun  6 10:03:51.279: :cc_get_feature_vsa malloc success
Jun  6 10:03:51.279:  cc_get_feature_vsa count is 1
Jun  6 10:03:51.279: :FEATURE_VSA attributes are: feature_name:0,feature_time:1219807008,feature_id:13882
Jun  6 10:03:51.279: //1163276/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
Jun  6 10:03:51.279: //1163276/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x47D299A4
Jun  6 10:03:51.283: //1163276/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Interface=0x471599EC, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Jun  6 10:03:51.299: //1163277/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
   Call Entry Is Not Found
Jun  6 10:03:51.299: //-1/1D07A340882A/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=0669
   ----- ccCallInfo IE subfields -----
   cisco-ani=0669
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=907703722056
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jun  6 10:03:51.299: //-1/1D07A340882A/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x47283FE0, Call Info(
   Calling Number=0669,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=907703722056(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1000, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1163277
Jun  6 10:03:51.299: //-1/1D07A340882A/CCAPI/ccCheckClipClir:
   In: Calling Number=0669(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=0669(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Jun  6 10:03:51.299: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun  6 10:03:51.299: :cc_get_feature_vsa malloc success
Jun  6 10:03:51.299:  cc_get_feature_vsa count is 2
Jun  6 10:03:51.299: :FEATURE_VSA attributes are: feature_name:0,feature_time:1219806784,feature_id:13883
Jun  6 10:03:51.299: //1163277/1D07A340882A/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=0669(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=907703722056(TON=Unknown, NPI=Unknown))
Jun  6 10:03:51.303: //1163277/1D07A340882A/CCAPI/cc_process_call_setup_ind:
   Event=0x47B23718
Jun  6 10:03:51.303: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 907703722056
Jun  6 10:03:51.303: //1163277/1D07A340882A/CCAPI/ccCallSetContext:
   Context=0x48A60E50
   >>>>CCAPI handed cid 1163277 with tag 1000 to app "_ManagedAppProcess_Default"
Jun  6 10:03:51.307: //1163277/1D07A340882A/CCAPI/ccCallProceeding:
Jun  6 10:03:51.311: //1163277/1D07A340882A/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1004, Params=0x48A5F0C0, Progress Indication=NULL(0)
Jun  6 10:03:51.311: //1163277/1D07A340882A/CCAPI/ccCheckClipClir:
   In: Calling Number=01612410669(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=01612410669(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=9T, Called Number=07703722056, Digit Strip=FALSE
   Calling Number=01612410669(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=07703722056(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=MHP Support
   Account Number=0669, Final Destination Flag=TRUE,
   Guid=1D07A340-8F5B-11E0-882A-AEEDE92CAADB, Outgoing Dial-peer=1004
Jun  6 10:03:51.311: //1163277/1D07A340882A/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=0669
   cisco-ani=01612410669
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=07703722056
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jun  6 10:03:51.311: //1163277/1D07A340882A/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x47283FE0, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=01612410669,(Calling Name=MHP Support)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=07703722056(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1004, Call Count On=FALSE,
Jun  6 10:03:51.311: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun  6 10:03:51.311: :cc_get_feature_vsa malloc success
Jun  6 10:03:51.311:  cc_get_feature_vsa count is 3
Jun  6 10:03:51.311: :FEATURE_VSA attributes are: feature_name:0,feature_time:1219806560,feature_id:13884
Jun  6 10:03:51.311: //1163278/1D07A340882A/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Jun  6 10:03:51.311: //1163278/1D07A340882A/CCAPI/ccCallSetContext:
   Context=0x48A5F070
Jun  6 10:03:51.311: //1163277/1D07A340882A/CCAPI/ccSaveDialpeerTag:
Jun  6 10:03:51.315: //1163278/1D07A340882A/CCAPI/cc_api_call_proceeding:
   Interface=0x47283FE0, Progress Indication=NULL(0)
Jun  6 10:03:55.815: //1163278/1D07A340882A/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=1163278,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Jun  6 10:03:55.815: //1163277/1D07A340882A/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=1163277,
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1)
Jun  6 10:03:55.815: //1163278/1D07A340882A/CCAPI/cc_api_event_indication:
   Event=154, Call Id=1163278
   Event Is Sent To Conferenced SPI(s) Directly
Jun  6 10:03:55.815: //1163278/1D07A340882A/CCAPI/cc_api_call_cut_progress:
   Interface=0x47283FE0, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=0
   Call Entry(Responsed=TRUE)
Jun  6 10:03:55.815: //1163277/1D07A340882A/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Jun  6 10:03:55.815: //1163277/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x45ED6014, callID1=0x11C00D, callID2=0x11C00E, tag=0x0)
   (confID=0x45ED6014, callID1=0x11C00D, gcid=1D083F68-8F5B11E0-882DAEED-E92CAADB, tag=0x0)
Jun  6 10:03:55.815: //1163278/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x45ED6014, callID2=0x11C00E, gcid=1D083F68-8F5B11E0-882DAEED-E92CAADB, tag=0x0)
Jun  6 10:03:55.815: //1163277/1D07A340882A/CCAPI/ccConferenceCreate:
   Conference Id=0x45ED6014, Call Id1=1163277, Call Id2=1163278, Tag=0x0
Jun  6 10:03:55.815: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=1, dtmf1=6
                    ret2=0, codecMask2=1, bytes2=160, negot2=1, dtmf2=6,
                    tx_dynamic_pt1=0, rx_dynamic_pt1=0, codec_mode1=0, params_bitmap1 =0
                    tx_dynamic_pt2=0, rx_dynamic_pt2=0, codec_mode2=0, params_bitmap2 =0
Jun  6 10:03:55.819: //1163277/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   delay media to slow start case, codec negotation is not done
Jun  6 10:03:55.819: //1163277/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Jun  6 10:03:55.819: cc_api_get_xcode_stream : 4510
Jun  6 10:03:55.819: //1163277/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B07, Source Interface=0x47283FE0, Source Call Id=1163277,
   Destination Call Id=1163278, Disposition=0x0, Tag=0x0
Jun  6 10:03:55.819: //1163278/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Jun  6 10:03:55.819: //1163278/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B07, Source Interface=0x47283FE0, Source Call Id=1163278,
   Destination Call Id=1163277, Disposition=0x0, Tag=0x0
Jun  6 10:03:55.819: //1163277/1D07A340882A/CCAPI/cc_generic_bridge_done:
Jun  6 10:03:55.819: //1163277/1D07A340882A/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x1B07, Destination Call Id=1163278)
Jun  6 10:03:55.819: //1163278/1D07A340882A/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x1B07, Destination Call Id=1163277)
Jun  6 10:03:55.819: //1163277/1D07A340882A/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1B07, Call Id1=1163277, Call Id2=1163278
Jun  6 10:03:55.831: //1163276/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x18E00, Params=0x47B076D0, Call Id=1163276
   Nominator=0x0, Params=0x47B07150, Call Id=1163276
Jun  6 10:03:55.831: //1163276/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x471599EC, Call Id=1163276
Jun  6 10:03:55.835: //1163276/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
   Nominator=0x47B073D0, Params=0x47B073A8, Call Id=1163276
Jun  6 10:03:55.835: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Jun  6 10:03:55.835: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun  6 10:03:55.835: :cc_get_feature_vsa malloc success
Jun  6 10:03:55.835:  cc_get_feature_vsa count is 4
Jun  6 10:03:55.835: :FEATURE_VSA attributes are: feature_name:0,feature_time:1219806336,feature_id:13885
Jun  6 10:03:55.835: //1163279/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Jun  6 10:03:55.835: //1163279/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x47D29FFC
   Interface=0x46FFE72C, Interface Type=27, Destination=, Mode=0x0,
Jun  6 10:03:55.835:  cc_get_feature_vsa count is 5
Jun  6 10:03:55.835: :FEATURE_VSA attributes are: feature_name:0,feature_time:1219806112,feature_id:13886
Jun  6 10:03:55.835: //1163280/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Interface=0x46FFE72C, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
Jun  6 10:03:55.835: //1163280/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=27, FlowMode=1
Jun  6 10:03:55.835: //1163280/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x47D2A39C
Jun  6 10:03:55.835: //1163279/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Connection Handle=0
Jun  6 10:03:55.843: //1163280/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x47B07368, callID1=0x11C010, callID2=0x11C00C, tag=0x0)
   (confID=0x47B07368, callID1=0x11C010, gcid=0-0-0-0, tag=0x0)
Jun  6 10:03:55.843: //1163276/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x47B07368, callID2=0x11C00C, gcid=0-0-0-0, tag=0x0)
   Conference Id=0x47B07368, Call Id1=1163280, Call Id2=1163276, Tag=0x0
Jun  6 10:03:55.843: //1163280/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B08, Source Interface=0x46FFE72C, Source Call Id=1163280,
   Destination Call Id=1163276, Disposition=0x0, Tag=0x0
Jun  6 10:03:55.843: //1163276/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B08, Source Interface=0x471599EC, Source Call Id=1163276,
   Destination Call Id=1163280, Disposition=0x0, Tag=0x0
Jun  6 10:03:55.843: //1163280/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x1B08, Destination Call Id=1163276)
   Call Entry(Conference Id=0x1B08, Destination Call Id=1163280)
   (confID=0x47B07398, callID1=0x11C010, callID2=0x11C00F, tag=0x0)
   (confID=0x47B07398, callID1=0x11C010, gcid=0-0-0-0, tag=0x0)
Jun  6 10:03:55.843: //1163279/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x47B07398, callID2=0x11C00F, gcid=0-0-0-0, tag=0x0)
   Conference Id=0x47B07398, Call Id1=1163280, Call Id2=1163279, Tag=0x0
   Conference Id=0x1B09, Source Interface=0x46FFE72C, Source Call Id=1163280,
   Destination Call Id=1163279, Disposition=0x0, Tag=0x0
Jun  6 10:03:55.843: //1163279/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B09, Source Interface=0x471599EC, Source Call Id=1163279,
   Call Entry(Conference Id=0x1B09, Destination Call Id=1163279)
   Call Entry(Conference Id=0x1B09, Destination Call Id=1163280)
Jun  6 10:03:55.843: //1163279/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x0, Params=0x47B06E78, Call Id=1163279
Jun  6 10:03:55.843: //1163280/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x1000000, Params=0x47B06E70, Call Id=1163280
Jun  6 10:03:55.847: //1163280/xxxxxxxxxxxx/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1B08, Call Id1=1163280, Call Id2=1163276
   Conference Id=0x1B09, Call Id1=1163280, Call Id2=1163279
Jun  6 10:03:55.847: //1163279/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x471599EC, Call Id=1163279
Jun  6 10:03:55.847: //1163279/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
   Nominator=0x47B073D0, Params=0x47B073A8, Call Id=1163279
Jun  6 10:03:55.891: //1163279/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x18E00, Params=0x47B076D0, Call Id=1163279
Jun  6 10:03:55.891: //1163279/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
Jun  6 10:03:55.891: //1163279/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
Jun  6 10:04:00.543: //1163276/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x800, Params=0x47B076D0, Call Id=1163276
Jun  6 10:04:00.547: //1163276/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
Jun  6 10:04:00.547: //1163280/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x1000000, Params=0x47B07740, Call Id=1163280
Jun  6 10:04:00.547: //1163277/1D07A340882A/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x47283FE0, Call Id=1163277
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Jun  6 10:04:00.551: //1163277/1D07A340882A/CCAPI/ccConferenceDestroy:
   Conference Id=0x1B07, Tag=0x0
Jun  6 10:04:00.551: //1163277/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jun  6 10:04:00.551: //1163278/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jun  6 10:04:00.551: //1163277/1D07A340882A/CCAPI/cc_generic_bridge_done:
Jun  6 10:04:00.551: //1163276/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
Jun  6 10:04:00.551: //1163280/xxxxxxxxxxxx/CCAPI/ccConferenceDestroy:
   Conference Id=0x1B08, Tag=0x0
Jun  6 10:04:00.551: //1163280/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Jun  6 10:04:00.551: //1163276/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jun  6 10:04:00.551: //1163280/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
Jun  6 10:04:00.551: //1163278/1D07A340882A/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jun  6 10:04:00.555: //1163277/1D07A340882A/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Jun  6 10:04:00.559: //1163279/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x800, Params=0x47B076D0, Call Id=1163279
Jun  6 10:04:00.559: //1163279/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
Jun  6 10:04:00.563: //1163277/1D07A340882A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x47283FE0, Tag=0x0, Call Id=1163277,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jun  6 10:04:00.563: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun  6 10:04:00.563: :cc_free_feature_vsa freeing 48B4C638
Jun  6 10:04:00.563:  vsacount in free is 4
Jun  6 10:04:00.571: //1163276/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
   Cause Value=0, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=0, Call Entry(Responsed=TRUE, Cause Value=0)
Jun  6 10:04:00.571: //1163279/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
Jun  6 10:04:00.571: //1163280/xxxxxxxxxxxx/CCAPI/ccConferenceDestroy:
   Conference Id=0x1B09, Tag=0x0
Jun  6 10:04:00.571: //1163280/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Jun  6 10:04:00.571: //1163279/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jun  6 10:04:00.571: //1163280/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
Jun  6 10:04:00.571: //1163276/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x471599EC, Tag=0x0, Call Id=1163276,
   Call Entry(Disconnect Cause=0, Voice Class Cause Code=0, Retry Count=0)
Jun  6 10:04:00.571: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun  6 10:04:00.571: :cc_free_feature_vsa freeing 48B4C718
Jun  6 10:04:00.571:  vsacount in free is 3
Jun  6 10:04:00.579: //1163279/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
Jun  6 10:04:00.583: //1163279/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x471599EC, Tag=0x0, Call Id=1163279,
Jun  6 10:04:00.583: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun  6 10:04:00.583: :cc_free_feature_vsa freeing 48B4C478
Jun  6 10:04:00.583:  vsacount in free is 2
Jun  6 10:04:00.587: //1163280/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
Jun  6 10:04:00.587: //1163280/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46FFE72C, Tag=0x0, Call Id=1163280,
Jun  6 10:04:00.587: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun  6 10:04:00.587: :cc_free_feature_vsa freeing 48B4C398
Jun  6 10:04:00.587:  vsacount in free is 1
Jun  6 10:04:00.595: //1163278/1D07A340882A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x47283FE0, Tag=0x0, Call Id=1163278,
Jun  6 10:04:00.595: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun  6 10:04:00.599: :cc_free_feature_vsa freeing 48B4C558
Jun  6 10:04:00.599: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun  6 10:04:00.599:  vsacount in free is 0
Thanks again.
If you look in the debug
   Context=0x47D299A4
   Connection Handle=0
   cisco-username=0669
   cisco-ani=0669
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=907703722056
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Apply that on the dial-peer voice 1000 voip
the translation profile.
now apply that voice translation profile on dial-peer vocie 1000
dial-peer voice1000 voip
translation-profile outgoing change_ani.
If this does not work and if you can not send me the running config. then Please open a TAC case.
sumit
Hi Sumit,
This did not work, but i will try the cucm way. to see if that works.
I would just like to thank you for all your help so far.
@Nathan,
I assume the call flow is IP Phone ----> CUCM --->h323 ----> Voice GW ---->?? (Is it PRI/SIP/H323)?
Do you know how
cisco-username=0669
changes to
Can you post
sh run | sec dial.* voip
sh run | sec dial.*pots
sh run | sec voice
What type of dial-peer is Outgoing Dial-peer=1004?
Without which we are just going to be running around in circles. if you are worried about passwords/IP Addresses, just post the running-config without the sensitive info.
/divin
Not everything in life is this tough!
I think we need to tell the Nathan what exactly he needs to solve the problem. Rather than to beat around the bush
Hi dijohn,
Any help is appreciated.
Yeah .. We all are here to help you. But, We need your inputs like the config/debugs to point you in the right direction.Assistance is a 2 way street!
/divin
Hi Dijohn,
Hope this helps.
I assume the call flow is IP Phone ----> CUCM --->h323 ----> Voice GW - SIP
Do you know how - no
cisco-username=0669
changes to
cisco-ani=01612410669 – Geo Number - 08708630002 - Non Geo
Can you post
Convrge_CUBE#sh run | sec dial.* voip
dial-peer voice 1004 voip
description description ** Outgoing call to SIP trunk (Generic SIP Trunk Pro
translation-profile outgoing PSTN_Outgoing
destination-pattern 9T
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
codec g711ulaw
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
description ** Incoming call from SIP trunk **
incoming called-number .%
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1 voip
description Incoming dialplan from CUCMBE
answer-address .T
incoming called-number .T
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 3847 voip
description Dialplan to CUCMBE
translation-profile outgoing Append_Prefix_Missed_Call
destination-pattern 441612413847$
session target ipv4:172.16.2.10
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 3848 voip
destination-pattern 441612413848$
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 3840 voip
destination-pattern 441612413840$
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 3841 voip
destination-pattern 441612413841$
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 3842 voip
destination-pattern 441612413842$
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 3843 voip
destination-pattern 441612413843$
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 3844 voip
destination-pattern 441612413844$
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 3845 voip
destination-pattern 441612413845$
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 3846 voip
destination-pattern 441612413846$
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 9999 voip
description Dialplan to SIP Provider
preference 10
destination-pattern .T
session target ipv4:88.215.60.40
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 3849 voip
destination-pattern 441612413849$
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 600 voip
destination-pattern 4416124106..
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 601 voip
description Test Conference
translation-profile outgoing Test_External_Conference
destination-pattern 441612410653
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 9382 voip
destination-pattern 441612419382$
dtmf-relay rtp-nte
codec g711ulaw
None
sh run | sec voice
boot system flash:c2800nm-ipvoice_ivs-mz.124-22.T1.bin
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711alaw
sip
  registrar server expires max 3600 min 3600
  localhost dns:192.168.1.1
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice translation-rule 3
rule 1 /^44\(161241....$\)/ /0\1/
voice translation-rule 4
rule 1 /441612413849/ /3849/
voice translation-rule 5
rule 1 /441612413850/ /3850/
voice translation-rule 10
rule 1 /^9\(.*\)/ /\1/
voice translation-rule 15
rule 1 /\(.*\)/ /9\1/
voice translation-rule 16
rule 1 /3847/ /08458738888/
voice translation-rule 23
rule 1 /441612417746/ /7746/
rule 2 /441612417747/ /7747/
rule 3 /441612417748/ /7748/
voice translation-rule 24
rule 1 /441612413840/ /3840/
rule 2 /441612413841/ /3841/
rule 3 /441612413842/ /3842/
rule 4 /441612413843/ /3843/
rule 5 /441612413844/ /3844/
rule 6 /441612413845/ /3845/
rule 7 /441612413846/ /3846/
rule 9 /441612413848/ /3848/
rule 10 /441612413849/ /3849/
voice translation-rule 25
rule 1 /01612410653/ /5555/
voice translation-rule 30
rule 1 /^/ /0/
voice translation-rule 31
rule 1 // /0/
voice translation-rule 40
rule 1 /44........../ //
voice translation-rule 410
rule 1 /^9\(.......)\)$/ /441\1/
rule 2 /^9\(.*\)/ /\1/
voice translation-rule 1111
rule 1 /\(....\)/ /0161241\1/
rule 2 /\(....\)/ /44161241\1/
rule 3 /\(....\)/ /44161241\1/
rule 4 /3849/ /441612413849/
rule 5 /3847/ /08458738888/
rule 6 /0669/ /08708630002/
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 1115
rule 10 /\(....\)/ /0161241\1/
voice translation-rule 2001
rule 1 /441612413360/ /6000/
voice translation-rule 2222
voice translation-profile Append_Prefix_Missed_Call
translate calling 15
voice translation-profile BLOCK_CALLER_ID
translate calling 40
voice translation-profile CallBlocking
translate called 2222
voice translation-profile FAX_Called
translate called 4
voice translation-profile IW-DDI
translate called 25
voice translation-profile MainDDI_Called
translate calling 31
translate called 24
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate calling 1111
translate called 1112
voice translation-profile OUT_DID
translate calling 3
voice translation-profile PSTN_CallForwarding
translate redirect-called 410
voice translation-profile PSTN_Outgoing
voice translation-profile Parity_Test_Outbound
translate calling 16
voice translation-profile STRIP9
translate called 10
voice translation-profile Test_External_Conference
translate called 25
voice translation-profile add0in
translate calling 30
voice-card 0
dspfarm
dsp services dspfarm
snmp-server enable traps voice fallback poor-qov
dtmf-relay rtp-nte
codec g711ulaw
no vad
dtmf-relay rtp-nte
codec g711ulaw
no vad
answer-address .T
dtmf-relay rtp-nte
codec g711ulaw
dtmf-relay rtp-nte
codec g711ulaw
dtmf-relay rtp-nte
codec g711ulaw
dtmf-relay rtp-nte
codec g711ulaw
dtmf-relay rtp-nte
codec g711ulaw
dtmf-relay rtp-nte
codec g711ulaw
dtmf-relay rtp-nte
codec g711ulaw
dtmf-relay rtp-nte
codec g711ulaw
dtmf-relay rtp-nte
codec g711ulaw
dtmf-relay rtp-nte
codec g711ulaw
preference 10
dtmf-relay rtp-nte
codec g711ulaw
no vad
dtmf-relay rtp-nte
codec g711ulaw
dtmf-relay rtp-nte
codec g711ulaw
dtmf-relay rtp-nte
codec g711ulaw
dtmf-relay rtp-nte
codec g711ulaw
dtmf-relay rtp-nte
codec g711ulaw
no vad
Thanks Again
You need to reorder the xlation rules
to
rule 1 /0669/ /08708630002/
rule 2 /\(....\)/ /0161241\1/
rule 4 /\(....\)/ /44161241\1/
rule 5 /3849/ /441612413849/
rule 6 /3847/ /08458738888/
These rules do a first MATCH and then they don't process any further. hence have the MORE specific matches on the top of the list
let me know if that helps
Hi Dijohn,
This has now changed the number 01612419382 which i believe is our billable number, but it is not showing 08708630002
Can you do the same debug
debug ccsip messages ( i assume that you are using a cube to connect to the SIP ITSP)
It could be that the SIP Provider or someone on the way is masking the digits to your billable number.
/divin
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2011.06.06 13:17:54 =~=~=~=~=~=~=~=~=~=~=~=
sh      sho log
Syslog logging: enabled (0 messages dropped, 63594 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: disabled
    Monitor logging: level debugging, 1426 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 7631 messages logged, xml disabled,
                     filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
    Trap logging: level informational, 118 message lines logged
--More--
Log Buffer (5000000 bytes):
612413841@X.X.X.X:5060>;expires=57, <441612413847>;expires=8, <441612413849>;expires=19, <441612413842>;expires=60
Server: SER (i386/linux)
Content-Length: 0
Warning: 392 X.X.X.X:5060 "Noisy feedback tells:  pid=32458 req_src_ip=X.X.X.X req_src_port=63265 in_uri=sip:SIP Provider:5060 out_uri=sip:SIP Provider:5060 via_cnt==1"
Jun  6 12:15:22.914: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:SIP Provider:5060 SIP/2.0
Date: Mon, 06 Jun 2011 12:15:22 GMT
Timestamp: 1307362522
Content-Length: 0
User-Agent: Cisco-SIPGateway/IOS-12.x
To: <441612413843>
Contact: <441612413843>
Expires:  60 --More--
Call-ID: 80003C6F-45A311E0-8005AEED-E92CAADB
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7DCF9D
CSeq: 269983 REGISTER
Max-Forwards: 70
Jun  6 12:15:22.938: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413843>
Content-Length: 0
Jun  6 12:15:22.942: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
--More--                           Received:
SIP/2.0 401 Unauthorized
To: <441612413843>;tag=f402f6743e9d1abe62785b2653c63db2.ec8e
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc4e4d4b8e2ea388eb33f735242f119d26ece"
Content-Length: 0
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="e68396e37feff0bcf13a66bb75f7ea55",nonce="4decc4e4d4b8e2ea388eb33f735242f119d26ece",algorithm=md5 --More--
Content-Length: 0
To: <441612413843>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7DD115F
CSeq: 269984 REGISTER
Max-Forwards: 70
Jun  6 12:15:22.962: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413843>
Server: SER (i386/linux) --More--
Content-Length: 0
Warning: 392 X.X.X.X:5060 "Noisy feedback tells:  pid=32453 req_src_ip=X.X.X.X req_src_port=63265 in_uri=sip:SIP Provider:5060 out_uri=sip:SIP Provider:5060 via_cnt==1"
Jun  6 12:15:22.970: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <441612413843>;tag=f402f6743e9d1abe62785b2653c63db2.6bae
Contact: <441612413845>;expires=20, <441612413843>;expires=60, <441612413848>;expires=1, <441612413846>;expires=24, <441612413841>;expires=56, <441612413847>;expires=7, <441612413849>;expires=18, <441612413842>;expires=59
Content-Length: 0
Jun  6 12:15:24.282: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:15:24 GMT
Timestamp: 1307362524
Content-Length: 0
To: <441612413848>
Contact: <441612413848>
Expires:  60
Call-ID: 800E4669-45A311E0-800AAEED-E92CAADB
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7DE133C
CSeq: 270014 REGISTER
Max-Forwards: 70
--More--
Jun  6 12:15:24.298: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413848>
Content-Length: 0
Warning: 392 X.X.X.X:5060 "Noisy feedback tells:  pid=32459 req_src_ip=X.X.X.X req_src_port=63265 in_uri=sip:SIP Provider:5060 out_uri=sip:SIP Provider:5060 via_cnt==1"
Received:
To: <441612413848>;tag=f402f6743e9d1abe62785b2653c63db2.7375 --More--
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc4e538cbc6d3b1d4851fac0df311b9179132"
Content-Length: 0
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="c6d9eb623f5d6d422f4575a455f1de62",nonce="4decc4e538cbc6d3b1d4851fac0df311b9179132",algorithm=md5
Content-Length: 0 --More--
To: <441612413848>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7DF2341
CSeq: 270015 REGISTER
Max-Forwards: 70
Jun  6 12:15:24.310: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413848>
Content-Length: 0
Warning: 392 X.X.X.X:5060 "Noisy feedback tells:  pid=32458 req_src_ip=X.X.X.X req_src_port=63265 in_uri=sip:SIP Provider:5060 out_uri=sip:SIP Provider:5060 via_cnt==1" --More--
Jun  6 12:15:24.322: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <441612413848>;tag=f402f6743e9d1abe62785b2653c63db2.ba27
Contact: <441612413845>;expires=19, <441612413843>;expires=59, <441612413848>;expires=60, <441612413846>;expires=23, <441612413841>;expires=55, <441612413847>;expires=6, <441612413849>;expires=17, <441612413842>;expires=58
Content-Length: 0
Jun  6 12:15:30.458: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:15:30 GMT
Timestamp: 1307362530
Content-Length: 0
To: <441612413847>
Contact: <441612413847>
Expires:  60
Call-ID: 800BD530-45A311E0-8009AEED-E92CAADB
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7E0A42
CSeq: 270002 REGISTER
Max-Forwards: 70
Jun  6 12:15:30.478: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying --More--
To: <441612413847>
Content-Length: 0
Warning: 392 X.X.X.X:5060 "Noisy feedback tells:  pid=32455 req_src_ip=X.X.X.X req_src_port=63265 in_uri=sip:SIP Provider:5060 out_uri=sip:SIP Provider:5060 via_cnt==1"
Received:
To: <441612413847>;tag=f402f6743e9d1abe62785b2653c63db2.ec6b
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc4eb29a73cbfbcae4ff58bc8f56f9f480223" --More--
Content-Length: 0
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="602539796a50af4ab5aca88921f77512",nonce="4decc4eb29a73cbfbcae4ff58bc8f56f9f480223",algorithm=md5
Content-Length: 0
To: <441612413847>
Expires: 60
Call-ID: 800BD530-45A311E0-8009AEED-E92CAADB --More--
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7E1697
CSeq: 270003 REGISTER
Max-Forwards: 70
Jun  6 12:15:30.498: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413847>
Content-Length: 0
Warning: 392 X.X.X.X:5060 "Noisy feedback tells:  pid=32457 req_src_ip=X.X.X.X req_src_port=63265 in_uri=sip:SIP Provider:5060 out_uri=sip:SIP Provider:5060 via_cnt==1"
Jun  6 12:15:30.514: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
--More--                           SIP/2.0 200 OK
To: <441612413847>;tag=f402f6743e9d1abe62785b2653c63db2.d714
Contact: <441612413845>;expires=13, <441612413843>;expires=53, <441612413848>;expires=54, <441612413846>;expires=17, <441612413841>;expires=49, <441612413847>;expires=60, <441612413849>;expires=11, <441612413842>;expires=52
Content-Length: 0
Jun  6 12:15:31.898: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
--More--                              Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Jun  6 12:15:31.898: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun  6 12:15:31.898: :cc_get_feature_vsa malloc success
Jun  6 12:15:31.898:  cc_get_feature_vsa count is 1
Jun  6 12:15:31.898: :FEATURE_VSA attributes are: feature_name:0,feature_time:1221258336,feature_id:13953
Jun  6 12:15:31.898: //1164401/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Jun  6 12:15:31.898: //1164401/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x47D293C0
Jun  6 12:15:31.902: //1164401/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Connection Handle=0
--More--                              Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Jun  6 12:15:31.910: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:907703722056@172.16.2.1:5060 SIP/2.0
Date: Sun, 05 Jun 2011 14:46:05 GMT
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
From: "MHP Support" <0669>;tag=e37c9741-237f-4d22-b22b-d679d9c3cf62-26723573
Allow-Events: presence
P-Asserted-Identity: "MHP Support" <0669>
Supported: timer,resource-priority,replaces
Min-SE:  1800
Remote-Party-ID: "MHP Support" <0669>;party=calling;screen=yes;privacy=off
Content-Length: 209
User-Agent: Cisco-CUCM7.0
To: <907703722056>
Contact: <0669>
Expires: 180
Content-Type: application/sdp
Call-ID: 8915fa00-deb196ad-d1-a0210ac@172.16.2.10
Via: SIP/2.0/TCP 172.16.2.10:5060;branch=z9hG4bKab51d3d637 --More--
CSeq: 101 INVITE
Session-Expires:  1800
Max-Forwards: 70
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 172.16.2.10
s=SIP Call
c=IN IP4 172.16.2.1
t=0 0
m=audio 17050 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Jun  6 12:15:31.914: //1164402/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
Jun  6 12:15:31.914: //-1/8229EB1388B2/CCAPI/cc_api_display_ie_subfields:
   cisco-username=0669
   cisco-ani=0669
--More--                              cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=907703722056
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jun  6 12:15:31.918: //-1/8229EB1388B2/CCAPI/cc_api_call_setup_ind_common:
--More--                              Incoming Dial-peer=1000, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=1164402
Jun  6 12:15:31.918: //-1/8229EB1388B2/CCAPI/ccCheckClipClir:
Jun  6 12:15:31.918: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun  6 12:15:31.918: :cc_get_feature_vsa malloc success
Jun  6 12:15:31.918:  cc_get_feature_vsa count is 2
Jun  6 12:15:31.918: :FEATURE_VSA attributes are: feature_name:0,feature_time:1221258112,feature_id:13954
Jun  6 12:15:31.918: //1164402/8229EB1388B2/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
--More--                              Called Number=907703722056(TON=Unknown, NPI=Unknown))
Jun  6 12:15:31.918: //1164402/8229EB1388B2/CCAPI/cc_process_call_setup_ind:
   Event=0x47B240E0
Jun  6 12:15:31.918: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Jun  6 12:15:31.918: //1164402/8229EB1388B2/CCAPI/ccCallSetContext:
   Context=0x48A5B4B0
   >>>>CCAPI handed cid 1164402 with tag 1000 to app "_ManagedAppProcess_Default"
Jun  6 12:15:31.926: //1164402/8229EB1388B2/CCAPI/ccCallProceeding:
Jun  6 12:15:31.926: //1164402/8229EB1388B2/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=1004, Params=0x48A62C80, Progress Indication=NULL(0)
Jun  6 12:15:31.926: //1164402/8229EB1388B2/CCAPI/ccCheckClipClir:
   In: Calling Number=08708630002(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=08708630002(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
--More--                           Jun  6 12:15:31.926: //1164402/8229EB1388B2/CCAPI/ccCallSetupRequest:
   Calling Number=08708630002(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Guid=8229EB13-8F6D-11E0-88B2-AEEDE92CAADB, Outgoing Dial-peer=1004
Jun  6 12:15:31.926: //1164402/8229EB1388B2/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=0669
   cisco-ani=08708630002
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=07703722056
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
--More--                              cisco-rdnpi=-1
   cisco-rdnsi=-1
Jun  6 12:15:31.926: //1164402/8229EB1388B2/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=08708630002,(Calling Name=MHP Support)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Jun  6 12:15:31.926: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun  6 12:15:31.926: :cc_get_feature_vsa malloc success
Jun  6 12:15:31.926:  cc_get_feature_vsa count is 3
--More--
Jun  6 12:15:31.926: :FEATURE_VSA attributes are: feature_name:0,feature_time:1221257888,feature_id:13955
Jun  6 12:15:31.930: //1164403/8229EB1388B2/CCAPI/ccIFCallSetupRequestPrivate:
Jun  6 12:15:31.930: //1164403/8229EB1388B2/CCAPI/ccCallSetContext:
   Context=0x48A62C30
Jun  6 12:15:31.930: //1164402/8229EB1388B2/CCAPI/ccSaveDialpeerTag:
Jun  6 12:15:31.930: //1164403/8229EB1388B2/CCAPI/cc_api_call_proceeding:
Jun  6 12:15:31.938: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 06 Jun 2011 12:15:31 GMT
Allow-Events: telephone-event
Content-Length: 0
To: <907703722056>
CSeq: 101 INVITE --More--
Server: Cisco-SIPGateway/IOS-12.x
Jun  6 12:15:31.958: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:07703722056@SIP Provider:5060 SIP/2.0
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
From: "MHP Support" <08708630002>;tag=E3967448-2648
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2183785235-2406289888-2293411565-3912018651
Timestamp: 1307362531
Content-Length: 253
To: <07703722056>
Contact: <08708630002>
Expires: 180
Content-Disposition: session;handling=required
Content-Type: application/sdp --More--
Call-ID: 822CF874-8F6D11E0-88B8AEED-E92CAADB@192.168.1.1
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7E2E63
CSeq: 101 INVITE
Max-Forwards: 69
v=0
o=CiscoSystemsSIP-GW-UserAgent 6320 3434 IN IP4 X.X.X.X
s=SIP Call
c=IN IP4 X.X.X.X
t=0 0
m=audio 16860 RTP/AVP 0 101
c=IN IP4 X.X.X.X
a=fmtp:101 0-15
a=ptime:20
Jun  6 12:15:31.978: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7E2E63 --More--
To: <07703722056>;tag=f0cd292e
CSeq: 101 INVITE
WWW-Authenticate: Digest nonce="1307362757087:5876ddf2d4a56d517b818a0dfada23f9",realm="SIP Provider"
Content-Length: 0
Received:
SIP/2.0 100 Trying
To: <07703722056>
CSeq: 101 INVITE
Content-Length: 0
Jun  6 12:15:31.982: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
--More--                           ACK sip:07703722056@SIP Provider:5060 SIP/2.0
Content-Length: 0
CSeq: 101 ACK
Max-Forwards: 70
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:07703722056@SIP Provider:5060",response="691b5067fe0fb587f97a75002ead4347",nonce="1307362757087:5876ddf2d4a56d517b818a0dfada23f9",algorithm=md5
Allow-Events: telephone-event --More--
Min-SE:  1800
Content-Length: 253
To: <07703722056>
Expires: 180
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7E3689
CSeq: 102 INVITE
Max-Forwards: 69
v=0
s=SIP Call
c=IN IP4 X.X.X.X
t=0 0 --More--
c=IN IP4 X.X.X.X
a=fmtp:101 0-15
a=ptime:20
Jun  6 12:15:32.010: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <07703722056>
CSeq: 102 INVITE
Content-Length: 0
Jun  6 12:15:38.886: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7E3689 --More--
Record-Route:
To: <07703722056>;tag=01253000b95ee07d
CSeq: 102 INVITE
Content-Length: 215
v=0
o=GASb2bua 9824 4557 IN IP4 88.215.60.41
s=SIP Call
c=IN IP4 88.215.60.33
t=0 0
m=audio 11404 RTP/AVP 0 101
a=fmtp:101 0-15
Jun  6 12:15:38.886: //1164403/8229EB1388B2/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=1164403,
--More--                              Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Jun  6 12:15:38.886: //1164402/8229EB1388B2/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=1164402,
Jun  6 12:15:38.886: //1164403/8229EB1388B2/CCAPI/cc_api_event_indication:
   Event=154, Call Id=1164403
Jun  6 12:15:38.890: //1164403/8229EB1388B2/CCAPI/cc_api_event_indication:
Jun  6 12:15:38.890: //1164403/8229EB1388B2/CCAPI/cc_api_call_cut_progress:
   Cause Value=0
Jun  6 12:15:38.890: //1164402/8229EB1388B2/CCAPI/ccCallCutProgress:
--More--                           Jun  6 12:15:38.890: //1164402/8229EB1388B2/CCAPI/ccCallCutProgress:
Jun  6 12:15:38.890: //1164402/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x45ED617C, callID1=0x11C472, callID2=0x11C473, tag=0x0)
   (confID=0x45ED617C, callID1=0x11C472, gcid=822A873B-8F6D11E0-88B5AEED-E92CAADB, tag=0x0)
Jun  6 12:15:38.890: //1164403/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x45ED617C, callID2=0x11C473, gcid=822A873B-8F6D11E0-88B5AEED-E92CAADB, tag=0x0)
Jun  6 12:15:38.890: //1164402/8229EB1388B2/CCAPI/ccConferenceCreate:
   Conference Id=0x45ED617C, Call Id1=1164402, Call Id2=1164403, Tag=0x0
Jun  6 12:15:38.890: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=1, dtmf1=6
--More--                           Jun  6 12:15:38.890: //1164402/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Jun  6 12:15:38.890: cc_api_get_xcode_stream : 4510
Jun  6 12:15:38.890: //1164402/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B33, Source Interface=0x47283FE0, Source Call Id=1164402,
   Destination Call Id=1164403, Disposition=0x0, Tag=0x0
Jun  6 12:15:38.890: //1164403/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Jun  6 12:15:38.890: //1164403/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B33, Source Interface=0x47283FE0, Source Call Id=1164403,
   Destination Call Id=1164402, Disposition=0x0, Tag=0x0
Jun  6 12:15:38.890: //1164402/8229EB1388B2/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x1B33, Destination Call Id=1164403)
Jun  6 12:15:38.894: //1164403/8229EB1388B2/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x1B33, Destination Call Id=1164402)
Jun  6 12:15:38.894: //1164402/8229EB1388B2/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1B33, Call Id1=1164402, Call Id2=1164403
Jun  6 12:15:38.894: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
--More--                           SIP/2.0 183 Session Progress
Supported: sdp-anat
Content-Length: 241
To: <907703722056>;tag=E3968F60-A75
Contact: <907703722056>
CSeq: 101 INVITE
v=0
o=CiscoSystemsSIP-GW-UserAgent 7881 7725 IN IP4 172.16.2.1
s=SIP Call
c=IN IP4 172.16.2.1
t=0 0 --More--
m=audio 18338 RTP/AVP 0 101
c=IN IP4 172.16.2.1
a=fmtp:101 0-16
a=ptime:20
Jun  6 12:15:38.902: //1164401/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x18E00, Params=0x47B076D0, Call Id=1164401
Jun  6 12:15:38.906: //1164401/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x0, Params=0x47B07150, Call Id=1164401
Jun  6 12:15:38.906: //1164401/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x471599EC, Call Id=1164401
Jun  6 12:15:38.906: //1164401/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
   Nominator=0x47B073D0, Params=0x47B073A8, Call Id=1164401
Jun  6 12:15:38.906: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Jun  6 12:15:38.906: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun  6 12:15:38.906: :cc_get_feature_vsa malloc success
Jun  6 12:15:38.906:  cc_get_feature_vsa count is 4
Jun  6 12:15:38.906: :FEATURE_VSA attributes are: feature_name:0,feature_time:1221257664,feature_id:13956
Jun  6 12:15:38.910: //1164404/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Jun  6 12:15:38.910: //1164404/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
   Context=0x47D2B290
Jun  6 12:15:38.910: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Jun  6 12:15:38.910: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun  6 12:15:38.910: :cc_get_feature_vsa malloc success
Jun  6 12:15:38.910:  cc_get_feature_vsa count is 5
Jun  6 12:15:38.910: :FEATURE_VSA attributes are: feature_name:0,feature_time:1221257440,feature_id:13957
Jun  6 12:15:38.910: //1164405/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Connection Handle=0
Jun  6 12:15:38.910: //1164405/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Jun  6 12:15:38.910: //1164405/xxxxxxxxxxxx/CCAPI/ccCallSetContext:
--More--                              Context=0x47D26D3C
Jun  6 12:15:38.910: //1164404/xxxxxxxxxxxx/CCAPI/cc_api_call_connected:
   Connection Handle=0
Jun  6 12:15:38.914: //1164405/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x47B07368, callID1=0x11C475, callID2=0x11C471, tag=0x0)
   (confID=0x47B07368, callID1=0x11C475, gcid=0-0-0-0, tag=0x0)
Jun  6 12:15:38.914: //1164401/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x47B07368, callID2=0x11C471, gcid=0-0-0-0, tag=0x0)
   Conference Id=0x47B07368, Call Id1=1164405, Call Id2=1164401, Tag=0x0
Jun  6 12:15:38.914: //1164405/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B34, Source Interface=0x46FFE72C, Source Call Id=1164405,
   Destination Call Id=1164401, Disposition=0x0, Tag=0x0
Jun  6 12:15:38.914: //1164401/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B34, Source Interface=0x471599EC, Source Call Id=1164401,
   Destination Call Id=1164405, Disposition=0x0, Tag=0x0
Jun  6 12:15:38.914: //1164405/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
--More--                           Jun  6 12:15:38.918: //1164405/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x1B34, Destination Call Id=1164401)
Jun  6 12:15:38.918: //1164401/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x1B34, Destination Call Id=1164405)
   (confID=0x47B07398, callID1=0x11C475, callID2=0x11C474, tag=0x0)
   (confID=0x47B07398, callID1=0x11C475, gcid=0-0-0-0, tag=0x0)
Jun  6 12:15:38.918: //1164404/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x47B07398, callID2=0x11C474, gcid=0-0-0-0, tag=0x0)
   Conference Id=0x47B07398, Call Id1=1164405, Call Id2=1164404, Tag=0x0
Jun  6 12:15:38.918: //1164405/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B35, Source Interface=0x46FFE72C, Source Call Id=1164405,
   Destination Call Id=1164404, Disposition=0x0, Tag=0x0
Jun  6 12:15:38.918: //1164404/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x1B35, Source Interface=0x471599EC, Source Call Id=1164404,
Jun  6 12:15:38.918: //1164405/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x1B35, Destination Call Id=1164404)
--More--                           Jun  6 12:15:38.918: //1164404/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x1B35, Destination Call Id=1164405)
Jun  6 12:15:38.918: //1164404/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x0, Params=0x47B06E78, Call Id=1164404
Jun  6 12:15:38.918: //1164405/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x1000000, Params=0x47B06E70, Call Id=1164405
Jun  6 12:15:38.922: //1164405/xxxxxxxxxxxx/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x1B34, Call Id1=1164405, Call Id2=1164401
   Conference Id=0x1B35, Call Id1=1164405, Call Id2=1164404
Jun  6 12:15:38.922: //1164404/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x471599EC, Call Id=1164404
Jun  6 12:15:38.922: //1164404/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
   Nominator=0x47B073D0, Params=0x47B073A8, Call Id=1164404
Jun  6 12:15:38.966: //1164404/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x18E00, Params=0x47B076D0, Call Id=1164404
Jun  6 12:15:38.966: //1164404/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
Jun  6 12:15:38.966: //1164404/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
Jun  6 12:15:41.166: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:SIP Provider:5060 SIP/2.0 --More--
Date: Mon, 06 Jun 2011 12:15:41 GMT
Timestamp: 1307362541
Content-Length: 0
To: <441612413849>
Contact: <441612413849>
Expires:  60
Call-ID: 801D881A-45A311E0-800BAEED-E92CAADB
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7E41721
CSeq: 269991 REGISTER
Max-Forwards: 70
Jun  6 12:15:41.178: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413849>
CSeq: 269991 REGISTER --More--
Content-Length: 0
Warning: 392 X.X.X.X:5060 "Noisy feedback tells:  pid=32451 req_src_ip=X.X.X.X req_src_port=63265 in_uri=sip:SIP Provider:5060 out_uri=sip:SIP Provider:5060 via_cnt==1"
Received:
To: <441612413849>;tag=f402f6743e9d1abe62785b2653c63db2.7876
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc4f64c128fe347bdf6de98102169fdf39243"
Content-Length: 0
Warning: 392 X.X.X.X:5060 "Noisy feedback tells:  pid=32451 req_src_ip=X.X.X.X req_src_port=63265 in_uri=sip:SIP Provider:5060 out_uri=sip:SIP Provider:5060 via_cnt==1" --More--
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="8697f572439c2e414e0d347e793f0deb",nonce="4decc4f64c128fe347bdf6de98102169fdf39243",algorithm=md5
Content-Length: 0
To: <441612413849>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7E5166
CSeq: 269992 REGISTER
Max-Forwards: 70
--More--                           Jun  6 12:15:41.194: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413849>
Content-Length: 0
Jun  6 12:15:41.218: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <441612413849>;tag=f402f6743e9d1abe62785b2653c63db2.5dd2
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7E5166 --More--
Contact: <441612413845>;expires=2, <441612413843>;expires=42, <441612413848>;expires=43, <441612413846>;expires=6, <441612413841>;expires=38, <441612413847>;expires=49, <441612413849>;expires=60, <441612413842>;expires=41
Content-Length: 0
Jun  6 12:15:41.902: //1164401/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x800, Params=0x47B076D0, Call Id=1164401
Jun  6 12:15:41.902: //1164401/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
Jun  6 12:15:41.902: //1164405/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x1000000, Params=0x47B07740, Call Id=1164405
Jun  6 12:15:41.902: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
--More--                           CANCEL sip:907703722056@172.16.2.1:5060 SIP/2.0
Content-Length: 0
To: <907703722056>
CSeq: 101 CANCEL
Max-Forwards: 70
Jun  6 12:15:41.906: //1164402/8229EB1388B2/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x47283FE0, Call Id=1164402
Jun  6 12:15:41.906: //1164402/8229EB1388B2/CCAPI/ccConferenceDestroy:
   Conference Id=0x1B33, Tag=0x0
Jun  6 12:15:41.906: //1164402/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jun  6 12:15:41.906: //1164403/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
--More--                              Destination Call Id=1164402, Disposition=0x0, Tag=0x0
Jun  6 12:15:41.906: //1164402/8229EB1388B2/CCAPI/cc_generic_bridge_done:
Jun  6 12:15:41.906: //1164401/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
Jun  6 12:15:41.906: //1164405/xxxxxxxxxxxx/CCAPI/ccConferenceDestroy:
   Conference Id=0x1B34, Tag=0x0
Jun  6 12:15:41.906: //1164405/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Jun  6 12:15:41.910: //1164401/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jun  6 12:15:41.910: //1164405/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
Jun  6 12:15:41.910: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
From: "MHP Support" <0669>;tag=e37c9741-237f-4d22-b22b-d679d9c3cf62-26723573 --More--
Content-Length: 0
To: <907703722056>
CSeq: 101 CANCEL
Jun  6 12:15:41.910: //1164403/8229EB1388B2/CCAPI/ccCallDisconnect:
Jun  6 12:15:41.910: //1164402/8229EB1388B2/CCAPI/ccCallDisconnect:
Jun  6 12:15:41.914: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:07703722056@SIP Provider:5060 SIP/2.0
Reason: Q.850;cause=16
Date: Mon, 06 Jun 2011 12:15:31 GMT --More--
Content-Length: 0
To: <07703722056>
CSeq: 102 CANCEL
Max-Forwards: 70
Sent:
SIP/2.0 487 Request Cancelled
Content-Length: 0
CSeq: 101 INVITE
Jun  6 12:15:41.914: //1164404/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x800, Params=0x47B076D0, Call Id=1164404
Jun  6 12:15:41.914: //1164404/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
Jun  6 12:15:41.918: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:907703722056@172.16.2.1:5060 SIP/2.0
Content-Length: 0
CSeq: 101 ACK
Max-Forwards: 70
--More--
Jun  6 12:15:41.918: //1164402/8229EB1388B2/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x47283FE0, Tag=0x0, Call Id=1164402,
Jun  6 12:15:41.918: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun  6 12:15:41.918: :cc_free_feature_vsa freeing 48CAEB78
Jun  6 12:15:41.918:  vsacount in free is 4
Jun  6 12:15:41.926: //1164401/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
Jun  6 12:15:41.926: //1164404/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
Jun  6 12:15:41.930: //1164405/xxxxxxxxxxxx/CCAPI/ccConferenceDestroy:
   Conference Id=0x1B35, Tag=0x0
Jun  6 12:15:41.930: //1164405/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
--More--                              Conference Id=0x1B35, Source Interface=0x46FFE72C, Source Call Id=1164405,
Jun  6 12:15:41.930: //1164404/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jun  6 12:15:41.930: //1164405/xxxxxxxxxxxx/CCAPI/cc_generic_bridge_done:
Jun  6 12:15:41.930: //1164401/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x471599EC, Tag=0x0, Call Id=1164401,
Jun  6 12:15:41.930: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun  6 12:15:41.930: :cc_free_feature_vsa freeing 48CAEC58
Jun  6 12:15:41.930:  vsacount in free is 3
Jun  6 12:15:41.938: //1164404/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
--More--                              Cause Value=0, Call Entry(Responsed=TRUE, Cause Value=0)
Jun  6 12:15:41.938: //1164404/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x471599EC, Tag=0x0, Call Id=1164404,
Jun  6 12:15:41.938: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun  6 12:15:41.938: :cc_free_feature_vsa freeing 48CAE9B8
Jun  6 12:15:41.938:  vsacount in free is 2
Jun  6 12:15:41.946: //1164405/xxxxxxxxxxxx/CCAPI/ccCallDisconnect:
Jun  6 12:15:41.946: //1164405/xxxxxxxxxxxx/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x46FFE72C, Tag=0x0, Call Id=1164405,
Jun  6 12:15:41.946: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
--More--
Jun  6 12:15:41.946: :cc_free_feature_vsa freeing 48CAE8D8
Jun  6 12:15:41.946:  vsacount in free is 1
Jun  6 12:15:41.966: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <07703722056>;tag=30f32f66
CSeq: 102 CANCEL
Content-Length: 0
Jun  6 12:15:41.966: //1164403/8229EB1388B2/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x47283FE0, Tag=0x0, Call Id=1164403,
Jun  6 12:15:41.966: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
--More--                           Jun  6 12:15:41.966: :cc_free_feature_vsa freeing 48CAEA98
Jun  6 12:15:41.970: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun  6 12:15:41.970:  vsacount in free is 0
Jun  6 12:15:41.970: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request Terminated
CSeq: 102 INVITE
Content-Length: 0
Jun  6 12:15:41.974: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Content-Length: 0
To: <07703722056>;tag=01253000b95ee07d --More--
CSeq: 102 ACK
Max-Forwards: 70
Jun  6 12:15:42.966: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:15:42 GMT
Timestamp: 1307362542
Content-Length: 0
To: <441612413845>
Expires:  60
Call-ID: 8005BB08-45A311E0-8007AEED-E92CAADB
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7E681F
CSeq: 270009 REGISTER
Max-Forwards: 70
--More--
Jun  6 12:15:42.982: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413845>
Content-Length: 0
Warning: 392 X.X.X.X:5060 "Noisy feedback tells:  pid=32454 req_src_ip=X.X.X.X req_src_port=63265 in_uri=sip:SIP Provider:5060 out_uri=sip:SIP Provider:5060 via_cnt==1"
Received:
To: <441612413845>;tag=f402f6743e9d1abe62785b2653c63db2.98aa --More--
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc4f8d24d3d07ea8f5981902ee67b75adf1b8"
Content-Length: 0
Jun  6 12:15:42.986: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="4ffcce89ff26e7dd60924f7d00db58f5",nonce="4decc4f8d24d3d07ea8f5981902ee67b75adf1b8",algorithm=md5
To: <441612413845>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7E7269F
CSeq: 270010 REGISTER
Max-Forwards: 70
Jun  6 12:15:43.006: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413845>
Content-Length: 0
Warning: 392 X.X.X.X:5060 "Noisy feedback tells:  pid=32452 req_src_ip=X.X.X.X req_src_port=63265 in_uri=sip:SIP Provider:5060 out_uri=sip:SIP Provider:5060 via_cnt==1" --More--
Jun  6 12:15:43.014: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <441612413845>;tag=f402f6743e9d1abe62785b2653c63db2.ac6e
Contact: <441612413845>;expires=60, <441612413843>;expires=40, <441612413848>;expires=41, <441612413846>;expires=4, <441612413841>;expires=36, <441612413847>;expires=47, <441612413849>;expires=58, <441612413842>;expires=39
Content-Length: 0
Jun  6 12:15:47.190: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:15:47 GMT
Timestamp: 1307362547
Content-Length: 0
To: <441612413846>
Contact: <441612413846>
Expires:  60
Call-ID: 8008C7D0-45A311E0-8008AEED-E92CAADB
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7E8E94
Max-Forwards: 70
Jun  6 12:15:47.202: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <441612413846>
Content-Length: 0
Warning: 392 X.X.X.X:5060 "Noisy feedback tells:  pid=32456 req_src_ip=X.X.X.X req_src_port=63265 in_uri=sip:SIP Provider:5060 out_uri=sip:SIP Provider:5060 via_cnt==1"
Jun  6 12:15:47.206: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <441612413846>;tag=f402f6743e9d1abe62785b2653c63db2.935e
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc4fc5f539e68e791b3ce0158460b368efe56" --More--
Content-Length: 0
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="c21451100c69a0c82cf929e634de5aad",nonce="4decc4fc5f539e68e791b3ce0158460b368efe56",algorithm=md5
Content-Length: 0
To: <441612413846>
Expires: 60
Call-ID: 8008C7D0-45A311E0-8008AEED-E92CAADB --More--
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7E9229B
Max-Forwards: 70
Jun  6 12:15:47.218: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413846>
Content-Length: 0
Jun  6 12:15:47.282: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <441612413846>;tag=f402f6743e9d1abe62785b2653c63db2.732a
Contact: <441612413845>;expires=56, <441612413843>;expires=36, <441612413848>;expires=37, <441612413846>;expires=60, <441612413841>;expires=32, <441612413847>;expires=43, <441612413849>;expires=54, <441612413842>;expires=35
Content-Length: 0
Jun  6 12:16:18.914: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:16:18 GMT
Timestamp: 1307362578
Content-Length: 0
To: <441612413841>
Contact: <441612413841>
Expires:  60
Call-ID: 7FFABE6F-45A311E0-8003AEED-E92CAADB
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7EA1C86
Max-Forwards: 70
Jun  6 12:16:18.950: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413841>
CSeq: 270014 REGISTER --More--
Content-Length: 0
Warning: 392 X.X.X.X:5060 "Noisy feedback tells:  pid=32460 req_src_ip=X.X.X.X req_src_port=63265 in_uri=sip:SIP Provider:5060 out_uri=sip:SIP Provider:5060 via_cnt==1"
Received:
To: <441612413841>;tag=f402f6743e9d1abe62785b2653c63db2.65e3
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc51cba1486c3f379b605caf033164a9d5dcd"
Content-Length: 0
Warning: 392 X.X.X.X:5060 "Noisy feedback tells:  pid=32460 req_src_ip=X.X.X.X req_src_port=63265 in_uri=sip:SIP Provider:5060 out_uri=sip:SIP Provider:5060 via_cnt==1" --More--
Jun  6 12:16:18.954: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="3b37a128113988d53161b81f602f6c89",nonce="4decc51cba1486c3f379b605caf033164a9d5dcd",algorithm=md5
Content-Length: 0
To: <441612413841>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7EB1B6D
Max-Forwards: 70
--More--                           Jun  6 12:16:18.966: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413841>
Content-Length: 0
Jun  6 12:16:18.982: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <441612413841>;tag=f402f6743e9d1abe62785b2653c63db2.3c3b
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7EB1B6D --More--
Contact: <441612413845>;expires=24, <441612413843>;expires=4, <441612413848>;expires=5, <441612413846>;expires=28, <441612413841>;expires=60, <441612413847>;expires=11, <441612413849>;expires=22, <441612413842>;expires=3
Content-Length: 0
Jun  6 12:16:22.070: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:16:22 GMT
Timestamp: 1307362582
Content-Length: 0
User-Agent: Cisco-SIPGateway/IOS-12.x --More--
To: <441612413842>
Contact: <441612413842>
Expires:  60
Call-ID: 7FFD2FA8-45A311E0-8004AEED-E92CAADB
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7EC4C3
CSeq: 269986 REGISTER
Max-Forwards: 70
Jun  6 12:16:22.086: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413842>
Content-Length: 0
Warning: 392 X.X.X.X:5060 "Noisy feedback tells:  pid=32457 req_src_ip=X.X.X.X req_src_port=63265 in_uri=sip:SIP Provider:5060 out_uri=sip:SIP Provider:5060 via_cnt==1" --More--
Jun  6 12:16:22.090: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <441612413842>;tag=f402f6743e9d1abe62785b2653c63db2.66cd
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc51f7e33e5824051a50573eb0912fcfd97db"
Content-Length: 0
Sent:
--More--                           REGISTER sip:SIP Provider:5060 SIP/2.0
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="1b753d9cc538bc0aab3b8ac704d96232",nonce="4decc51f7e33e5824051a50573eb0912fcfd97db",algorithm=md5
Content-Length: 0
To: <441612413842>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7ED2154
CSeq: 269987 REGISTER
Max-Forwards: 70
Jun  6 12:16:22.102: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413842> --More--
Content-Length: 0
Jun  6 12:16:22.118: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <441612413842>;tag=f402f6743e9d1abe62785b2653c63db2.5cb9
Contact: <441612413845>;expires=21, <441612413843>;expires=1, <441612413848>;expires=2, <441612413846>;expires=25, <441612413841>;expires=57, <441612413847>;expires=8, <441612413849>;expires=19, <441612413842>;expires=60 --More--
Content-Length: 0
Jun  6 12:16:22.970: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Content-Length: 0
To: <441612413843>
Expires:  60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7EECB
CSeq: 269985 REGISTER
Max-Forwards: 70 --More--
Jun  6 12:16:22.986: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413843>
Content-Length: 0
Jun  6 12:16:22.990: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <441612413843>;tag=f402f6743e9d1abe62785b2653c63db2.25e0 --More--
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc520ebd3ea69fe2370fd42a07b8335183312"
Content-Length: 0
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="b6914aebc31a1ae0387419e3f63aa1e3",nonce="4decc520ebd3ea69fe2370fd42a07b8335183312",algorithm=md5
To: <441612413843>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7EF96D
Max-Forwards: 70
Jun  6 12:16:22.998: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413843>
Content-Length: 0
Warning: 392 X.X.X.X:5060 "Noisy feedback tells:  pid=32456 req_src_ip=X.X.X.X req_src_port=63265 in_uri=sip:SIP Provider:5060 out_uri=sip:SIP Provider:5060 via_cnt==1" --More--
Jun  6 12:16:23.046: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <441612413843>;tag=f402f6743e9d1abe62785b2653c63db2.a04c
Content-Length: 0
Jun  6 12:16:24.322: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:16:24 GMT
Timestamp: 1307362584
Content-Length: 0
To: <441612413848>
Expires:  60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7F0226B
CSeq: 270016 REGISTER
Max-Forwards: 70
Jun  6 12:16:24.334: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <441612413848>
Content-Length: 0
Received:
To: <441612413848>;tag=f402f6743e9d1abe62785b2653c63db2.6ec7
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc5217b09053ed380aeaee6ecad1f6a4e346e" --More--
Content-Length: 0
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="a846875f023f6fee37bc61f2ee2a1a1e",nonce="4decc5217b09053ed380aeaee6ecad1f6a4e346e",algorithm=md5
Content-Length: 0
To: <441612413848>
Expires: 60
Call-ID: 800E4669-45A311E0-800AAEED-E92CAADB --More--
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7F1DB4
CSeq: 270017 REGISTER
Max-Forwards: 70
Jun  6 12:16:24.346: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413848>
Content-Length: 0
Jun  6 12:16:24.366: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <441612413848>;tag=f402f6743e9d1abe62785b2653c63db2.62f4
Content-Length: 0
Jun  6 12:16:30.514: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:16:30 GMT
Timestamp: 1307362590
Content-Length: 0
To: <441612413847>
Expires:  60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7F21F31
CSeq: 270004 REGISTER
Max-Forwards: 70
Jun  6 12:16:30.526: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413847>
CSeq: 270004 REGISTER --More--
Content-Length: 0
Received:
To: <441612413847>;tag=f402f6743e9d1abe62785b2653c63db2.eb39
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc527b44b9e32997667906a309ce21fa35313"
Content-Length: 0
Warning: 392 X.X.X.X:5060 "Noisy feedback tells:  pid=32454 req_src_ip=X.X.X.X req_src_port=63265 in_uri=sip:SIP Provider:5060 out_uri=sip:SIP Provider:5060 via_cnt==1" --More--
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="f69020e73f0b1d411edadc482b8b5e04",nonce="4decc527b44b9e32997667906a309ce21fa35313",algorithm=md5
Content-Length: 0
To: <441612413847>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7F32244
CSeq: 270005 REGISTER
Max-Forwards: 70
--More--                           Jun  6 12:16:30.542: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413847>
Content-Length: 0
Jun  6 12:16:30.554: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <441612413847>;tag=f402f6743e9d1abe62785b2653c63db2.b244
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7F32244 --More--
Content-Length: 0
Jun  6 12:16:41.218: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:16:41 GMT
Timestamp: 1307362601
Content-Length: 0
To: <441612413849>
Expires:  60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7F4ECD
CSeq: 269993 REGISTER
Max-Forwards: 70
Jun  6 12:16:41.230: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413849>
Content-Length: 0
Received:
To: <441612413849>;tag=f402f6743e9d1abe62785b2653c63db2.2f11
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc53206e66dfcf887ededc169667d0ea3da26"
Content-Length: 0
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="e1320501a033c8e4d88e9f80e4c1a272",nonce="4decc53206e66dfcf887ededc169667d0ea3da26",algorithm=md5
Content-Length: 0
To: <441612413849>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7F5258A
CSeq: 269994 REGISTER
Max-Forwards: 70
Jun  6 12:16:41.242: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413849> --More--
Content-Length: 0
Jun  6 12:16:41.258: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <441612413849>;tag=f402f6743e9d1abe62785b2653c63db2.c3e7
Contact: <441612413845>;expires=2, <441612413843>;expires=42, <441612413848>;expires=43, <441612413846>;expires=6, <441612413841>;expires=38, <441612413847>;expires=49, <441612413849>;expires=60, <441612413842>;expires=41 --More--
Content-Length: 0
Jun  6 12:16:43.014: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:16:43 GMT
Timestamp: 1307362603
Content-Length: 0
To: <441612413845>
Expires:  60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7F624F0
CSeq: 270011 REGISTER
Jun  6 12:16:43.022: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413845>
Content-Length: 0
Jun  6 12:16:43.026: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <441612413845>;tag=f402f6743e9d1abe62785b2653c63db2.6f13 --More--
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc534ffe3949b8ea96b0d1dce6867fc46c3ab"
Content-Length: 0
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="c6365cd43fbd8d1a39136da4435d29ce",nonce="4decc534ffe3949b8ea96b0d1dce6867fc46c3ab",algorithm=md5
To: <441612413845>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7F7E9E
CSeq: 270012 REGISTER
Max-Forwards: 70
Jun  6 12:16:43.034: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413845>
Content-Length: 0
Jun  6 12:16:43.050: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <441612413845>;tag=f402f6743e9d1abe62785b2653c63db2.2082
Content-Length: 0
Jun  6 12:16:47.282: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:16:47 GMT
Timestamp: 1307362607
Content-Length: 0
To: <441612413846>
Expires:  60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7F8873
Max-Forwards: 70
Jun  6 12:16:47.294: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <441612413846>
Content-Length: 0
Received:
To: <441612413846>;tag=f402f6743e9d1abe62785b2653c63db2.df96
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc538ae6ef97a4990ebe7b0e73028b3161dde" --More--
Content-Length: 0
Jun  6 12:16:47.298: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="79e078778a49a8bed2a8780b02b594f5",nonce="4decc538ae6ef97a4990ebe7b0e73028b3161dde",algorithm=md5
Content-Length: 0
To: <441612413846>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7F91759
Max-Forwards: 70
Jun  6 12:16:47.318: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413846>
Content-Length: 0
Jun  6 12:16:47.330: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <441612413846>;tag=f402f6743e9d1abe62785b2653c63db2.ec6d
Content-Length: 0
Jun  6 12:17:18.982: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:17:18 GMT
Timestamp: 1307362638
Content-Length: 0
To: <441612413841>
Expires:  60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7FABBF
Max-Forwards: 70
Jun  6 12:17:19.010: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413841>
CSeq: 270016 REGISTER --More--
Content-Length: 0
Received:
To: <441612413841>;tag=f402f6743e9d1abe62785b2653c63db2.f239
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc55813c9054e3b18b907e88d544a8294139d"
Content-Length: 0
Sent:
Date: Mon, 06 Jun 2011 12:17:19 GMT
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="cae66e37f01c903443c6ef2dc6b3fcc6",nonce="4decc55813c9054e3b18b907e88d544a8294139d",algorithm=md5
Timestamp: 1307362639
Content-Length: 0
To: <441612413841>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7FB1131
Max-Forwards: 70
--More--                           Jun  6 12:17:19.042: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413841>
Content-Length: 0
Jun  6 12:17:19.058: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <441612413841>;tag=f402f6743e9d1abe62785b2653c63db2.09a8
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7FB1131 --More--
Content-Length: 0
Jun  6 12:17:22.118: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:17:22 GMT
Timestamp: 1307362642
Content-Length: 0
To: <441612413842>
Expires:  60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7FCDCF
CSeq: 269988 REGISTER
Max-Forwards: 70
Jun  6 12:17:22.130: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413842>
Content-Length: 0
Received:
To: <441612413842>;tag=f402f6743e9d1abe62785b2653c63db2.8556
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc55bbad2c7828dae19f23844f3c874769538"
Content-Length: 0
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="7318147763dc925537529402412f563a",nonce="4decc55bbad2c7828dae19f23844f3c874769538",algorithm=md5
Content-Length: 0
To: <441612413842>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7FD190A
CSeq: 269989 REGISTER
Max-Forwards: 70
Jun  6 12:17:22.142: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Content-Length: 0
Jun  6 12:17:22.166: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <441612413842>;tag=f402f6743e9d1abe62785b2653c63db2.52e2
Content-Length: 0
Jun  6 12:17:23.046: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:17:23 GMT
Timestamp: 1307362643
Content-Length: 0
To: <441612413843>
Expires:  60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7FE28D
Jun  6 12:17:23.058: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413843>
Content-Length: 0
Received:
To: <441612413843>;tag=f402f6743e9d1abe62785b2653c63db2.dbf4 --More--
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc55c7d30a430fc5a1fe11b048cb7a05aa5cd"
Content-Length: 0
Jun  6 12:17:23.062: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="a788a0ab269e346c0594b6f2bc5c6807",nonce="4decc55c7d30a430fc5a1fe11b048cb7a05aa5cd",algorithm=md5
To: <441612413843>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B7FFCF4
Max-Forwards: 70
Jun  6 12:17:23.070: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413843>
Content-Length: 0
Jun  6 12:17:23.082: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <441612413843>;tag=f402f6743e9d1abe62785b2653c63db2.729a
Contact: <441612413845>;expires=20, <441612413848>;expires=1, <441612413846>;expires=24, <441612413841>;expires=56, <441612413847>;expires=7, <441612413849>;expires=18, <441612413842>;expires=59, <441612413843>;expires=60
Content-Length: 0
Jun  6 12:17:24.366: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:17:24 GMT
Timestamp: 1307362644
Content-Length: 0
To: <441612413848>
Expires:  60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B80015
CSeq: 270018 REGISTER
Max-Forwards: 70
Jun  6 12:17:24.386: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <441612413848>
Content-Length: 0
Received:
To: <441612413848>;tag=f402f6743e9d1abe62785b2653c63db2.59d2
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc55df2ec387c26216d52683c18421b45a46a" --More--
Content-Length: 0
Jun  6 12:17:24.390: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="4eb579156c2a033ec38cc6238c5ba0a8",nonce="4decc55df2ec387c26216d52683c18421b45a46a",algorithm=md5
Content-Length: 0
To: <441612413848>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B8012249
CSeq: 270019 REGISTER
Max-Forwards: 70
Jun  6 12:17:24.422: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413848>
Content-Length: 0
Jun  6 12:17:24.434: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <441612413848>;tag=f402f6743e9d1abe62785b2653c63db2.94d4
Contact: <441612413845>;expires=19, <441612413848>;expires=60, <441612413846>;expires=23, <441612413841>;expires=55, <441612413847>;expires=6, <441612413849>;expires=17, <441612413842>;expires=58, <441612413843>;expires=59
Content-Length: 0
Jun  6 12:17:30.554: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:17:30 GMT
Timestamp: 1307362650
Content-Length: 0
To: <441612413847>
Expires:  60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B802246A
CSeq: 270006 REGISTER
Max-Forwards: 70
Jun  6 12:17:30.570: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413847>
CSeq: 270006 REGISTER --More--
Content-Length: 0
Jun  6 12:17:30.574: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <441612413847>;tag=f402f6743e9d1abe62785b2653c63db2.32a4
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc563c0e833b5e27d4b72dc136f5351a7d964"
Content-Length: 0
Warning: 392 X.X.X.X:5060 "Noisy feedback tells:  pid=32453 req_src_ip=X.X.X.X req_src_port=63265 in_uri=sip:SIP Provider:5060 out_uri=sip:SIP Provider:5060 via_cnt==1" --More--
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="5fdf2ed782cbc1924e9bf1e4e576ad8c",nonce="4decc563c0e833b5e27d4b72dc136f5351a7d964",algorithm=md5
Content-Length: 0
To: <441612413847>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B803126
CSeq: 270007 REGISTER
Max-Forwards: 70
--More--                           Jun  6 12:17:30.586: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413847>
Content-Length: 0
Jun  6 12:17:30.606: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <441612413847>;tag=f402f6743e9d1abe62785b2653c63db2.10f0
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B803126 --More--
Contact: <441612413845>;expires=13, <441612413848>;expires=54, <441612413846>;expires=17, <441612413841>;expires=49, <441612413847>;expires=60, <441612413849>;expires=11, <441612413842>;expires=52, <441612413843>;expires=53
Content-Length: 0
Jun  6 12:17:41.258: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:17:41 GMT
Timestamp: 1307362661
Content-Length: 0
To: <441612413849>
Expires:  60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B8047C8
CSeq: 269995 REGISTER
Max-Forwards: 70
Jun  6 12:17:41.274: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413849>
Content-Length: 0
Received:
To: <441612413849>;tag=f402f6743e9d1abe62785b2653c63db2.b9e8
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc56e36dd7177974ab67edf03dfb811e8a631"
Content-Length: 0
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="04ebf68e7785e06129acd2a6bc3dd35f",nonce="4decc56e36dd7177974ab67edf03dfb811e8a631",algorithm=md5
Content-Length: 0
To: <441612413849>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B805F34
CSeq: 269996 REGISTER
Max-Forwards: 70
Jun  6 12:17:41.294: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Content-Length: 0
Jun  6 12:17:41.306: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <441612413849>;tag=f402f6743e9d1abe62785b2653c63db2.c827
Contact: <441612413845>;expires=2, <441612413848>;expires=43, <441612413846>;expires=6, <441612413841>;expires=38, <441612413847>;expires=49, <441612413849>;expires=60, <441612413842>;expires=41, <441612413843>;expires=42 --More--
Content-Length: 0
Jun  6 12:17:43.050: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:17:43 GMT
Timestamp: 1307362663
Content-Length: 0
To: <441612413845>
Expires:  60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B8063AB
CSeq: 270013 REGISTER
Jun  6 12:17:43.062: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413845>
Content-Length: 0
Jun  6 12:17:43.066: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <441612413845>;tag=f402f6743e9d1abe62785b2653c63db2.1eb3 --More--
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc570f1689f1b3869a5d37df8e1cd3dbd6239"
Content-Length: 0
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="183d38d9ba1c557dd77116501bc88444",nonce="4decc570f1689f1b3869a5d37df8e1cd3dbd6239",algorithm=md5
To: <441612413845>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B807C78
Max-Forwards: 70
Jun  6 12:17:43.078: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413845>
Content-Length: 0
Jun  6 12:17:43.094: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
To: <441612413845>;tag=f402f6743e9d1abe62785b2653c63db2.b4fd
Contact: <441612413848>;expires=41, <441612413846>;expires=4, <441612413841>;expires=36, <441612413847>;expires=47, <441612413849>;expires=58, <441612413842>;expires=39, <441612413843>;expires=40, <441612413845>;expires=60
Content-Length: 0
Jun  6 12:17:47.330: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Mon, 06 Jun 2011 12:17:47 GMT
Timestamp: 1307362667
Content-Length: 0
To: <441612413846>
Expires:  60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B80823E3
Max-Forwards: 70
Jun  6 12:17:47.350: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <441612413846>
Content-Length: 0
Received:
To: <441612413846>;tag=f402f6743e9d1abe62785b2653c63db2.7b00
WWW-Authenticate: Digest realm="SIP Provider", nonce="4decc5743c5e4620092cef79cff932b04bb480d8" --More--
Content-Length: 0
Jun  6 12:17:47.354: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Authorization: Digest username="0001655233810",realm="SIP Provider",uri="sip:SIP Provider:5060",response="35dfdd267cea170c06119ae0567714d7",nonce="4decc5743c5e4620092cef79cff932b04bb480d8",algorithm=md5
Content-Length: 0
To: <441612413846>
Expires: 60
Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK22B809A9D
Max-Forwards: 70
Jun  6 12:17:47.374: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: <441612413846>
Content-Length: 0
Jun  6 12:17:47.386: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <441612413846>;tag=f402f6743e9d1abe62785b2653c63db2.a47e
Contact: <441612413848>;expires=37, <441612413846>;expires=60, <441612413841>;expires=32, <441612413847>;expires=43, <441612413849>;expires=54, <441612413842>;expires=35, <441612413843>;expires=36, <441612413845>;expires=56
Content-Length: 0
Convrge_CUBE#
We are sending the right calling number "08708630002"
Supported:100rel,timer,resourcepriority,replaces,sdp-anat        Min-SE:  1800
Cisco-Guid: 283785235-2406289888-2293411565-3912018651
Content-Length: 253
To: <07703722056>
Expires: 180
Call-ID: 822CF874-8F6D11E0-88B8AEED-92CAADB@192.168.1.1
CSeq: 102 INVITE
Max-Forwards: 69
Please talk to the provider about this. I don't think this a configuration problem on the router.
Hi Dijohn,
I will speak with the provider now and get back to you.
I appreciate the help.
Nathan
