01-16-2011 11:41 PM - edited 03-16-2019 02:54 AM
Hi all,
on of my clusters (CUCM 6.1, ExMob) shows a strange behaviour:
Two of my about 300 Users get their own Number shown in the phone display when they receive a call from external and not the telephone-number of the caller.
If they receive a call from internal, the screen shows the name and the number of the caller, absolutely correct.
It´s just two users that have this problem.
Deleting and recreating their ExMob and USer Porfiles did not solve the problem.
Does someone have an idea what is wrong on their profiles?
I compared it with fully functional profiles and did not see any differences and unfortunally I do not know wich keywords to use for a bug-toolkit search...
greetings
Christian
01-17-2011 07:31 AM
Do you have any transformation patterns in place?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
01-18-2011 06:36 AM
Hi Java,
there are no transformation pattern configured on the system.
The user told me that it is a little bit strange, because some ANI´s are shown ( some mobile numbers eg. ) and some are not.
greetings
Christian
01-18-2011 07:35 AM
Christian,
It would be worth starting at the beginning, try checking what the carrier is presenting to your gateway. I assume this is an ISDN connection?
If so you could try:-
term no mon
conf t
service sequence-number
logging buffered 51200000 debug
no logging rate-limit
no logging console
exit
This sets up the debugs to be buffered and not going to the console port or VTY ports.
Then setup a standard debug:-
debug isdn q931
When the user reports a problem log back on, set your terminal emulation program to log the output ot a file.
From EXEC prompt:-
Term len 0
show logg
Look through the file for the number and confirm what the carrier is sending in, it is as likely it's their problem as it's yours
To turn off the changes from EXEC prompt issue:-
Tem len 24
conf t
logging console
Try this and let us know, if the calling party number is correct is probably time to grab the CUCM logs.
Craig
PLEASE RATE HELPFUL POSTS!
01-21-2011 03:50 AM
Thank you very much for your detailed instructions on how to debug this.
Unfortunally, we have 4 PMX with 30 lines each and some thousands of calls a day.
Would this debugging might influence our gateway performance?
Is there another way to debug this maybe directly on the cucm ?
Greetings
Christian
01-21-2011 04:09 AM
Christian,
You can look at the CUCM logs as I suggested in my previous posting as the next setp, but it will be far more time consuming to read the logs AND the reason I suggested using a debug on the voice gateway was to take the whole CUCM out of the equation. If this shows an issue, it is 99% certain is a carrier issue.
Have a look at the RTMT guide regarding collecting CUCM logs here http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/6_0_1/rtmt/rttlc.html
As to the question of router loading, it depends on your chassis and what else it does.
120 channels and thousands of calls sounds SMALL and LOW VOLUME to me.
Craig
01-26-2011 02:09 AM
Hey Guys,
sorry for the delayed answer...
My Colleague on site just told me that it is depending on the extension mobile profile logged in to the phone and not to a specific phone.
Maybe this helps.
greetings
Christian
