WRP500 and BE600S ?
Catalin Sandu
I have 2 questions:
1. Does the Cisco CME - BE6000S works with WRP500-E-K9 Router ?
2. How is separate voice data of data(lan) traffic on WRP500-E-K9 Router?
Thank you!!
Jaime Valencia
Enterprise products are usually NOT tested with SMB products, you would need to POC that to find if they do work
For assistance with that router, you should post in the SMB community.
java
if this helps, please rate
