Can someone point out what special parameters that I need be aware when configuring XO SIP Trunk on CUCM 7.1? There is no CUBE involved in the connection.
I looked at the SIP Trunk configuration explaination on CallManager, it has a lot of different combinations of parameters which is confusing me.
Thanks for any tips.
JJ
Focus on SIP Information area where you put IP address of remote end, security and DTMF Signaling Method. Make sure you use correct CSS for outgoing and incmoing calls. Pretty much that's all, of course you need to add device pool, name of this trunk but thats obvious. Other settings leave default and you can change them later if you need after testing.
rate if this help
