3825 with flash:c3825-advsecurityk9-mz.151-4.M2.bin not able to config IPv6
john.hardman
Hi All
Despite what the feature navigator says, I am not able to configure IPv6 on this router.
show ver
#sh ver
Cisco IOS Software, 3800 Software (C3825-ADVSECURITYK9-M), Version 15.1(4)M2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Mon 26-Sep-11 18:53 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
PHXBackupR1 uptime is 15 minutes
System returned to ROM by reload at 16:43:00 Arizona Wed Oct 19 2011
System image file is "flash:c3825-advsecurityk9-mz.151-4.M2.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3825 (revision 1.2) with 1011712K/36864K bytes of memory.
Processor board ID FTX1333AJ0F
2 Gigabit Ethernet interfaces
3 Serial interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO3825             xxxxxxxxxxxxxxx
------------------------------------------------------------------------- end show ver ---------------------------------
------------------------------------------- Interface config try ----------------------------
PHXBackupR1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
PHXBackupR1(config)#int g0/0
PHXBackupR1(config-if)#ipv
PHXBackupR1(config-if)#ipv?
% Unrecognized command
PHXBackupR1(config-if)#ena?
-------------------------------------------- interface config try end ------------------------
I have tried enable ipv6 on the interface level, same. I have tried enable ipv6 at the global level, same. Non of the exe commands like ping or tracert have IPv6 options or counter parts (ping6 tracert6)
Kind of got me stumped here as IPv6 should have been support back in 12.4 on this platform.
What am I missing?
HI John,
IPv6 is not supported in the Advanced Security feature set, you need the Advanced IP services. For the complete list of feature set which support IPv6, please check with the feature navigator.
Laurent.
avayner
Have you entered the "ipv6 unicast-routing" command in the configuration?
Do you have it?
In global config mode "ipv" is a unrecognized command, so no, not available.
HI John,
Laurent.
