HSRP IPv6 problem
sebastien3
Level 4
Level 4
I have a problem with HSRP version 2 with 2 routers.
If I unplug on R1 GE0/0/3 and GE0/1/7 the failover IPv6 2001:db8:a:66::254 does not switch to R2.
Here is the configuration of the two routers and the diagram
############### R2 ###############
track 1 interface GigabitEthernet0/0/0 line-protocol
track 2 interface GigabitEthernet0/1/0 line-protocol
track 10 interface GigabitEthernet0/0/3 line-protocol
track 11 interface GigabitEthernet0/1/7 line-protocol
interface Port-channel2
 description *** UPLINK WAN ***
 standby 2 ipv6 2001:db8:1:1:1:FFFF:FFFF:5/125
 standby 2 timers msec 150 msec 450
 standby 2 priority 200
 standby 2 preempt
 standby 2 authentication md5 key-chain HSRP
 standby 2 name WAN_IPv6
 standby 2 track 10 decrement 10
 standby 2 track 11 decrement 10
 negotiation auto
 ipv6 address 2001:db8:1:1:1:FFFF:FFFF:2/125
 ipv6 enable
 no ipv6 redirects
 no ipv6 unreachables
interface Port-channel20.101
 description *** LAN ***
 encapsulation dot1Q 101
 standby version 2
 standby 101 ipv6 2001:db8:a:66::254/64
 standby 101 timers msec 150 msec 450
 standby 101 priority 150
 standby 101 preempt
 standby 101 authentication md5 key-chain HSRP_101
 standby 101 name LAN-101_IPv6
 standby 101 track 1 decrement 30
 standby 101 track 2 decrement 30
 ipv6 address 2001:db8:a:66::2/64
 ipv6 enable
 no ipv6 redirects
############### R1 ###############
interface Port-channel1
 standby version 2
 standby 2 priority 120
 standby 2 preempt
 negotiation auto
 ipv6 address 2001:db8:1:1:1:FFFF:FFFF:1/125
 ipv6 enable
 no ipv6 redirects
interface Port-channel10.101
 standby version 2
 standby 101 preempt
 ipv6 address 2001:db8:a:66::1/64
 ipv6 enable
 no ipv6 redirects
What did I forget in my configuration ?
Thanks for your help !!
sebastien3
Level 4
Level 4
I have an error on two routers :
-------- R2
%IPV6_ND-4-DUPLICATE_OPTIMISTIC: Duplicate address FE80::5:73FF:FEA0:65 on Port-channel20.101
-------- R1
%IPV6_ND-4-DUPLICATE_OPTIMISTIC: Duplicate address FE80::5:73FF:FEA0:65 on Port-channel10.101
Seb Rupik
Hi there,
What is the output show standby on both routers.
Also, on R1 Po10.101 you have not specified the dot1q tag (101).
cheers,
Seb,
sebastien3
Level 4
Level 4
Hello Seb,
Thank you for your reply. This is an error to copy/paste, the dot1q tag 101 is present.
I deleted all HSRP configuration and tried with VRRP. The configuration works perfectly !
