IPv4 and IPv6 address on PPPoE with ASA
I have ASA on which I'm using PPPoE to connect to ISP. I can get IPv4 address, but there is no way to get IPv6 address. Is there a way to do this on PPPoE connection on ASA? Is there version of SW which will have this?
Tyson Joachims
I'm sure the code version of your ASA will play a role in this but more importantly, is your ISP providing you with IPv6 addresses via the PPPoE connect? You'll need to check with them to ensure they are even setup to provide that and are actually sending them to you.
My provider gave me a IPv6 scope. I was using it on Cisco ISR router. I changed router with the ASA.
I don't get IPv6 address on PPPoE connection. I know it was not available until last time I checked (1Y ago). Is there any change? If it is, is there a configuration example? I have ASA 9.9 (2) software installed on my ASA.
