IPV6 cross LAN ping help
lolcomclips
I'm able to ping ipv4 across LANs (IT host to Operator Host for example) But I can't get a ipv6 ping for the life of me, I enabled unicast routing and configured the hosts and devices to the address table (word doc linked below) help plz
Harold Ritter
Hi @lolcomclips ,
Can you please provide the Packet Tracer file.
looking at the instructions, I am not sure what they want your IPv6 addressing to look like (or they made a mistake). The router has one interface in the 'A' subnet and one in the 'B' subnet. The PCs have A1/A2 and B1/B2 as suggested subnets, which obviously would not work.
I have attached a lab (saved in PT version with your setup, the hosts are in the same respective subnets. Check with your instructor if they want each host in a different subnet...
Hello
do the ipv6 hosts have the correct default-gateway
Kind Regards
Paul
