01-23-2015 09:48 AM - edited 03-01-2019 05:46 PM
This is a little ,off topic ,since the device isnt a CISCO device ...just uses the ios. here is my problem I have a setup on a switch using ipv4 igmp for multicasting . I need to test how this works using IPv6 and MLD ...so I have nearly the same configuration except for the word ipv6 = ip and mld = igmp. Like I said this is identical.
configure terminal
ipv6 mld snooping
ipv6 mld snooping vlan 1
ipv6 mld snooping fast-leave
ipv6 mld snooping vlan 1 fast-leave
ipv6 mld snooping query-interval 100
ipv6 mld snooping query-max-response-time 5
ipv6 mld snooping last-member-query-interval 1000
ipv6 mld snooping vlan 1 querier address fe80::1
ipv6 mld snooping vlan 1 query-interval 200
ipv6 mld snooping vlan 1 query-max-response-time 5
ipv6 mld snooping vlan 1 querier-timeout 100
ipv6 mld snooping vlan 1 last-member-query-interval 1000
ipv6 mld snooping vlan 1 discard-unknown
ipv6 mld snooping discard-unknown
the info on the port connected is
eth1 Link encap:Ethernet HWaddr 90:e2:ba:72:71:68
inet addr:10.50.0.2 Bcast:10.50.0.255 Mask:255.255.255.0
inet6 addr: fe80::92e2:baff:fe72:7168/64 Scope:Link
inet6 addr: 2012::2/64 Scope:Global
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:14 errors:0 dropped:0 overruns:0 frame:0
TX packets:140 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1207 (1.2 KB) TX bytes:18240 (18.2 KB)
but when I try and stream from VLC using rtp://[ff15:1]:5004 I see that my listener reports go out but i don't seem to be getting added to the group? ... I know this set up should work because if I remove the lines
and the traffic floods to all ports the stream starts playing in VLC ...
is there a problem with my IPv6 setup possibly?
01-28-2015 08:26 AM
disregard this its solve IPv6 wasn't properley enabled
