Ping From Node Using CSMP
376
mathaker
Contributor
This note illustrates how you can use the CSMP protocol to initiate an IPv6 ping from a CG-Mesh node to another IPv6 host at the head end.  In this example we use the CSMP CLI tool.  We also assume that CSMP message signing (a security measure) is not in use.
Here is how to issue the CSMP post to the node.
C:\>java -jar CsmpRequest-5.4.19.jar -r [2001:db8:3:9:1:3b0b:33:37] -P txreq.json.txt 30
log4j:WARN No appenders could be found for logger (com.cisco.cgms.protocols.coap.CoapClient).
log4j:WARN Please initialize the log4j system properly.
CoapMessage(transaction_type=ACK,status=201,bodylen=0)
Here is what the txreq.json.txt looks like:
C:\>type txreq.json.txt
{"dest":"[2001:db8:1:1:100::10]","count":3,"delay":1}
To get the ping results from the node, use this command:
C:\>java -jar CsmpRequest-5.4.19.jar -r [2001:db8:3:9:1:3b0b:33:37] 31
CoapMessage(transaction_type=ACK,status=205,bodylen=53)
[31/PingResponse]: {"sent": 3,"receieved": 2,"minRtt": 288,"meanRtt": 390,"maxRtt": 492,
"stdevRtt": 10404,"src": "[2001:db8:1:1:100:0:0:10%lowpan]"}
To monitor the ping packets, you may use packet monitoring on the FAN router:
CGR1240# ethanalyzer local interface wpan limit-captured-frames 0
total args=7
/usr/bin/sudo tshark -t ad -l -i wpan0
Capturing on interface(wpan0)
2013-08-22 10:23:02.698450 2001:db8:1:100::11 -> 2001:db8:3:9:1:3b0b:33:37 UDP Source port: 60368  Destination port: 61624
2013-08-22 10:23:03.108718 2001:db8:3:9:1:3b0b:33:37 -> 2001:db8:1:100::11 STUN2 ChannelData TURN Message
2013-08-22 10:23:04.108727 2001:db8:3:9:1:3b0b:33:37 -> 2001:db8:1:1:100::10 ICMPv6 Echo request
2013-08-22 10:23:04.120242 2001:db8:1:1:100::10 -> 2001:db8:3:9:1:3b0b:33:37 ICMPv6 Echo reply
2013-08-22 10:23:04.556996 2001:db8:3:9:: -> 2001:db8:1:1:100::10 ICMPv6 Unreachable (Route unreachable)
2013-08-22 10:23:05.355631 2001:db8:3:9:1:3b0b:33:37 -> 2001:db8:1:1:100::10 ICMPv6 Echo request
2013-08-22 10:23:05.357884 2001:db8:1:1:100::10 -> 2001:db8:3:9:1:3b0b:33:37 ICMPv6 Echo reply
2013-08-22 10:23:06.107551 2001:db8:3:9:1:3b0b:33:37 -> 2001:db8:1:1:100::10 ICMPv6 Echo request
2013-08-22 10:23:06.109831 2001:db8:1:1:100::10 -> 2001:db8:3:9:1:3b0b:33:37 ICMPv6 Echo reply
2013-08-22 10:23:27.535650 2001:db8:3:9:1:3b0b:33:37 -> 2001:db8:3:9:: ICMPv6 Unknown (0x9b) (Unknown (0x02))
Content for Community-Ad
