This RM701 combines the mobile IP capabilities of the Cisco 5915 Router with the Mobile Ad-Hoc Networking System (MANET) capability of the MPU3 card from Persistent Systems.
Hi, I am trying to do system install NSO 5.2.1.2 on Redhat Server. It was an offline server. so I did installed java and ant rpms manually and installed NSO. I can do ssh to nso cli, but I can not see ports opening up for webui. I ha...
view more
Hello, I am trying to send a 'show version' command to my Cisco ASA using Ansible, but I am encountering the following errors and I don't know why. The same thing works for my Cisco router though. Below are some details that might be helpful. Ci...
view more
Hi, I want to run a jsonrpc command to get the live-status of device hostname. I'm trying the below command but couldn't get succeed. Can any one help me to fix this ? Assume i got logged in and get_trans method ran successfully before exec...
view more
Hi all i am using JNC to manage device . Trying to delete specific node on basis of node value which is key to list .
I am trying to use markdelete(Str Path) to delete my node but node able to get correct path for my node with node-name value as getting p...
view more
we have a we-c3560x-24p switch with version 12.2 (55) SE5 that was off our network for a few years and we connected it back up to the network but it shows that there are a few devices connected to it but there is only 1 SFP connected in the G1/1. An...
view more
