Simple CMD Builder Script to do clear counters and then show interface
77
This document was generated from CDN thread
Created by: Dharmesh Shah on 13-09-2010 12:35:24 PM
Friends,
Basically you would want to do something like below via NV Cmd Builder Script
The IOS-XR syntax for it is
RP/0/RSP0/CPU0:testASR9006#clear counters TenGigE 0/0/0/0
Mon Sep 13 05:38:07.646 EDT
Clear "show interface" counters on this interface
Here is an illustration on how to use cmd builder scripts to do clear counters on IOS-XR v3.9.1
Create a BeanShell , Telnet Interface CMD Builder Script
The variables are
my_counter  Type Combo, Values Yes = 1 and No = 0, default = No
my_interface Type String
Then Create a Tab and include the above two variables
FInally paste this code in the script window
prompt="";
 if (my_counter.equals("1"))
    command = "clear counters "+my_interface;
    telnetInterface.config(prompt,command,true);
  prompt="#";
  command="";
command="show interface "+my_interface;
telnetInterface.config("#", command, true);
Content for Community-Ad
August's Community Spotlight Awards
