SSL VPN (AnyConnect) connection to CG-REDI
1910
This section describes the procedure to setup Cisco AnyConnect Secure Mobility Client based SSL VPN access to the CG-REDI infrastructure.  The supported operating systems are:
  1. Microsoft Windows
  2. Apple Mac OSX
  3. Various Linux distributions
Step 1:
Step 2:
  • Wait for the system to detect the platform (Windows, Mac or Linux) and Java installation
  • If Java is not found, please install JRE
  • Download and Install AnyConnect Client Software, by following the prompt on the screen
Step 3
  • Launch Cisco Anyconnect Secure Mobility Client
  • Connect to cgredi-vpngw.cisco.com (or 173.36.209.69) using the AnyConnect software
  • Provide login credentials
  • VPN should connect with the following message
nageshblore
Beginner
Step 1:
OK, so how do I reach out to whom for the credentials, please?
Steve Zhang
Hi Nagesh,
I guess you are trying to install something from the hosted RPM server. Since there is some special issue for our hosted RPM server(not sure when it will be available), please try to install it from the local RPM server. You may refer to Installing OpenJDK 7 JRE/JDK in GOS using local RPM server for reference.
Steve
chuli2
Hi Nagesh,
We are currently migrating our servers. Once we make it, will keep you posted.
Chun
nageshblore
Beginner
Thanks!
Create
Recognize Your Peers
Content for Community-Ad
