Toolkit problem
72
This document was generated from CDN thread
Created by: Luigi Borghetti on 05-10-2010 02:58:34 PM
I've got some problems with Cisco EnergyWise toolkit downloaded from Cisco CDN (Cisco-EnergyWise-Toolkit-1.0.409.tar). When I try to start RefAgent in folder /bin/Linux, the system say "./RefAgent cannot execute binary file". What I can do?
I'm working on a platform composed by:
- ARM9 (ATMEL)
- Linux Debian
The board is a Fox G20, produced by ACMESYSTEMS (in italy) http://www.acmesystems.it/foxg20/doku.php
Thank you very much.
Subject: RE: Toolkit problem
Replied by: Brad Schoening on 05-10-2010 03:43:31 PM
- ARM9 (ATMEL)
- Linux Debian
Luigi, for the ARM platform you will need the source distribution and compile it for your hardware/os platform.  The binary distribution includes RefAgent for a Linux/i86 architecture and Windows only.
You're firm downloaded the 1.2 alpha release of the source code as EnergywiseToolkit_20100830.tar on Sept 16th.  Please see if you can locate that, or I can send you another copy of it.
Brad
Replied by: Clint Cronwright on 13-09-2011 08:26:32 AM
Hi Luigi,
Did you get this compiled and working on the Foxboard?
Kind regards,
Clint.
Replied by: cui xiaoxia on 09-07-2013 02:14:24 AM
Hi Brad:
can you send me acopy of  the energywise sdk source code ?
I am working on support energywise in PDU production, the embedded system in PDU is lightweight RTOS called FREERTOS.
But I found that there are more library files in toolkit, FreeRTOS can’t know them, so, I can’t develop ENDPOINT client in PDU.
