Highlighted
A question about HA with 1 master and 2 slaves
Hi experts,
Got another HA question here. For HA, if I’m using the layer 2 VIP method and I have one master and two slaves, the configurations are as below:
ha token      cisco
ha interval   4
ha failure-limit 10
ha vip address    10.74.205.83
ha vip broadcast-address 10.74.205.127
ha member nso_m
address         10.74.205.71
default-ha-role master
vip-interface   eth2
ha member nso_s1
address         10.74.205.72
default-ha-role slave
failover-master true
vip-interface   eth3
ha member nso_s2
address         10.74.205.74
vip-interface   eth4
The question is about when I deactivate the master, slave 1 will become master and slave 2 (nso_s2) will become “none”. Is it normal that slave 2 will never be the slave under the new master even if I want to do it manually (like changing the HA configurations)?
best regards,
Gavin Lam
2 REPLIES 2
Highlighted
Re: A question about HA with 1 master and 2 slaves
Hi Gavin,
tailf-hcc does as little as possible automagically, by design. Is the master node goes down, the fail over master will become master, and that is it (alarms are generated etc ofc, screaming for manual intervention).
If you want s2 to become slave to the new master manual steps must be taken. There is an action for it, so no need to change configuration. I suggest you take look at the deployment guide, "section 5.1.6 - HA Disaster Recovery".
Wheter this is normal or not I cant say.
Highlighted
Hi Simon,
Thanks, and the HA action that you are suggesting is “force-be-slave-to member <member name>”, it’s good enough to know and have this manual way to let the slave go under the new master again.
Best regards,
Gavin
Content for Community-Ad
Cisco Community May 2020 Spotlight Award Winners
