As my config interface interface is ony one . I set the deivce name is constant value. But build failed.
list interface {
key name;
leaf name {
type leafref {
path "/ncs:devices/ncs:device[ncs:name='FB1']/ncs:config/cisco-ios-xr:interface/cisco-ios-xr:GigabitEthernet/cisco-ios-xr:id";
[root@ucs-sdn-7 src]# make
/nobackup/haofan/./nso/4.1.1/bin/ncsc `ls vrf-ann.yang > /dev/null 2>&1 && echo "-a vrf-ann.yang"` \
--yangpath yang --yangpath ../../cisco-iosxr-icon/src/ncsc-out/modules/yang -c -o ../load-dir/vrf.fxs yang/vrf.yang
yang/vrf.yang:37: error: bad argument value "/ncs:devices/ncs:device[ncs:name='FB1']/ncs:config/cisco-ios-xr:interface/cisco-ios-xr:GigabitEthernet/cisco-ios-xr:id", should be of type path-arg
make: *** [../load-dir/vrf.fxs] Error 1
And I try another methods tailf:link , but when run package reload failed.
list interface {
key name;
leaf name {
type string;
tailf:link "/ncs:devices/ncs:device[ncs:name='FB1']/ncs:config/cisco-ios-xr:interface/cisco-ios-xr:GigabitEthernet/cisco-ios-xr:id";
admin@ncs# packages reload
>>> System upgrade is starting.
>>> Sessions in configure mode must exit to operational mode.
>>> No configuration changes can be performed until upgrade has completed.
>>> System upgrade has been cancelled.
Error: Failed to load ./state/packages-in-use/1/vrf/load-dir/vrf.fxs: /services/vrf/interface/name: Missing keys in symlink: /ncs:devices/ncs:device[ncs:name='FB1']/ncs:config/cisco-ios-xr:interface/cisco-ios-xr:GigabitEthernet/cisco-ios-xr:id
To access an element within a list you just need to supply the key:
URL-For-The-List/key
Just like you have:
/devices/device/FB1
Bilal.
Ok. Got it
Hao Fan
Try normal URL encoding
http://www.w3schools.com/tags/ref_urlencode.asp
/ = %2F
curl -s -u admin:admin http://localhost:8080/api/running/devices/device/xr0/config/cisco-ios-xr:interface/GigabitEthernet/0%2F0%2F0%2F0
On 30 Aug 2016 at 13:23:21 , Hao Fan (haofan) (haofan@cisco.com) wrote:
curl -s -u admin:admin http://localhost:8080/api/running/devices/device/FB1/config/cisco-ios-xr:interface/GigabitEthernet can show all interface information. How can I only get one interface configurations , such as only get GigabitEthernet 0/0/0/0 configuration ?
<collection xmlns:y="http://tail-f.com/ns/rest">
<GigabitEthernet xmlns="http://tail-f.com/ned/cisco-ios-xr">
<id>0/0/0/0</id>
<description>connect to FB1</description>
<frequency xmlns="http://tail-f.com/ned/cisco-ios-xr">
<synchronization xmlns="http://tail-f.com/ned/cisco-ios-xr">
<quality xmlns="http://tail-f.com/ned/cisco-ios-xr">
<transmit xmlns="http://tail-f.com/ned/cisco-ios-xr">
<highest xmlns="http://tail-f.com/ned/cisco-ios-xr">
</highest>
</transmit>
</quality>
</synchronization>
</frequency>
<ipv4 xmlns="http://tail-f.com/ned/cisco-ios-xr">
<address xmlns="http://tail-f.com/ned/cisco-ios-xr">
<ip>11.1.1.2</ip>
<mask>255.255.255.0</mask>
</address>
<pim xmlns="http://tail-f.com/ned/cisco-ios-xr">
</pim>
<verify xmlns="http://tail-f.com/ned/cisco-ios-xr">
<unicast xmlns="http://tail-f.com/ned/cisco-ios-xr">
</unicast>
</verify>
</ipv4>
<ipv6 xmlns="http://tail-f.com/ned/cisco-ios-xr">
<nd xmlns="http://tail-f.com/ned/cisco-ios-xr">
<prefix xmlns="http://tail-f.com/ned/cisco-ios-xr">
</prefix>
</nd>
Hao Fan
