Community Helping Community
22
ALU NED capability
Hi NSO gurus,
Does the current ALU NEDs have the capability of ‘discovering’  attributes of a ALU 7210 (SAS-M; SAS-K) when the a ALU 7210 device is added to NSO ?
As part of the sync-from process, attributes I’d be looking for:
    • Serial Number
    • Number and details of SDPs on the device
    • Number of interfaces
    • Number of ports
    • SFP discovery on device ports
Thanks & Regards,
  Nick Khemani
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: ALU NED capability
The YANG device-model in a NED typically models the “configuration space” for the platform-family/vendor. Which usually equates to “show running-config” of sorts. So whatever is modelled there will get represented in the device instance in CDB after a sync-from. Anything else will need to modelled as operational/stats I guess.
I do see ”NED Capabilities” on the roadmap. Not sure what all that adds to the NED’s model.
Bilal.
1 REPLY 1
Bilal.
Content for Community-Ad
FusionCharts will render here
