01-02-2017 02:28 PM
I’m going in circles J and cannot start confd due to:
[config-sol@localhost confd-6.2]$ !840
confd --foreground --verbose
"Bad configuration: /home/config-sol/confd-6.2/etc/confd/confd.conf:0: cannot dynamically link with libcrypto shared library\n"
When I installed confd and got the error – so I went an installed the libcrypto per below – but still same issue.
REQUIRED LIBRARIES NOT FOUND
ConfD requires a version of the libcrypto.so library that could not
be found on your system:
libcrypto.so.1.0.0 => not found
The missing library must be installed using exactly the name shown above
to succesfully run ConfD. If you have the correct library version
installed using another name, this problem may be solved by creating a
symbolic link to the installed library with the name ConfD requires.
However, when I try to install that – it is not available. Seems the version is libcrypto.so.6:
[root@localhost ~]# yum install libcrypto.so.1.0.0
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: mirror.datto.com
* extras: centos-distro.cavecreek.net
* updates: mirror.net.cen.ct.gov
No package libcrypto.so.1.0.0 available.
Error: Nothing to do
[root@localhost ~]# yum install libcrypto.so.7
No package libcrypto.so.7 available.
[root@localhost ~]# yum install libcrypto.so.6
Package openssl098e-0.9.8e-29.el7.centos.3.i686 already installed and latest version
Nothing to do
[root@localhost ~]#
Solved! Go to Solution.
01-02-2017 02:30 PM
Hi Julie,
What is your use of ConfD? Is this a specific project driven need for ConfD or are you just experimenting?
You can also create a symbolic link with the required name for libcrypto.
--Nabil
01-02-2017 02:29 PM
Hi Team,
Just saw this:
In what directory do I create this symbolic link?
JA
01-02-2017 02:30 PM
Hi Julie,
--Nabil
01-02-2017 02:30 PM
Under /usr/lib64 run
ln -s libcrypto.so.1.0.1e libcrypto.so.1.0.0
01-02-2017 02:31 PM
It looks as though the Linux distro has OpenSSL 0.9.8e. Take a look at section 27.15 of the ConfD User's Guide and the instructions for that. If you have problems, let me know and I can work through them with you.
Best regards,
Greg Olin
01-02-2017 02:31 PM
I used Naom’s symbolic link – worked great.
JA
