397
raffovicisco01
Beginner
configuration using ncs_cli
Hi folks,
I'm following both the "NCS getting started guide" and the examples within the NCS installation directory. I was expecting to achieve the same result with both "$ ncs_cli -u admin" and "$ ncs_cli -C -u admin" shell but is not like this.
I'm trying to replicate the same configuration from the 5.5.3 Defining mapping ...
admin@ncs(config)# devices device c0 config ios:interface FastEthernet 10/10 switchport trunk allowed vlan
Possible completions:
  WORD     VLAN IDs of the allowed VLANs when this port is in trunking mode
  all      all VLANs
  except   all VLANs except the following
  none     no VLANs
admin@ncs(config)# devices device c0 config ios:interface FastEthernet 10/10 switchport trunk allowed vlan 1234
  <cr>
admin@ncs(config-if)# top
using the "$ ncs_cli -u admin" shell bou is not possible.
admin@ncs% edit devices device c1 config ios:interface FastEthernet 10/10 switchport trunk allowed vlan 1234
syntax error: expecting
  all    - all VLANs
  except - all VLANs except the following
  none   - no VLANs
  vlans  -
[error][2015-07-17 11:36:34]
Can you please help me understanding my fault and the difference between the two CLI mode?
Raffo
4 REPLIES 4
mike.elrom
Beginner
Hi Raffo,
Not sure if I completely understand your question, but the two CLI modes let operators use the CLI in a style either similar to Cisco or Juniper.  Juniper is the default.
ncs_cli -u admin -C
admin connected from 127.0.0.1 using console on mikes-mbp.home
admin@ncs# con
Entering configuration mode terminal
admin@ncs(config)#
ncs_cli -u admin -J
admin@ncs> con
Entering configuration mode private
[ok][2015-07-17 10:28:50]
[edit]
admin@ncs%
Furthermore, you can adjust some of the CLI prompt in the ncs.conf file:
  <cli>
    <enabled>true</enabled>
    <!-- Use the builtin SSH server -->
    <ssh>
      <ip>0.0.0.0</ip>
      <port>2024</port>
    </ssh>
    <prompt1>\u@ncs> </prompt1>
    <prompt2>\u@ncs% </prompt2>
    <c-prompt1>\u@ncs# </c-prompt1>
    <c-prompt2>\u@ncs(\m)# </c-prompt2>
    <show-log-directory>logs</show-log-directory>
    <show-commit-progress>true</show-commit-progress>
    <suppress-commit-message-context>maapi</suppress-commit-message-context>
    <suppress-commit-message-context>system</suppress-commit-message-context>
  </cli>
Mike
Ajay Pandey
Hi Raffo,
In the Juniper style (ncs_cli -u admin or ncs_cli -u admin -J), please try this :-
edit devices device c1 config ios:interface FastEthernet 10/10 switchport trunk allowed vlan 1234 vlans 1234
Ajay
Hi Ajay,
I tried it and it doesn't work :
admin@ncs% edit devices device c1 config ios:interface FastEthernet 10/10 switchport trunk allowed vlan 1234 vlans 1234
syntax error: element does not exist
[error][2015-07-20 11:59:19]
[edit]
Raffo
shooky@nil.si
Beginner
You are missing "vlans" right after vlan when using J style CLI. Note that the two styles render NED YANG models differently so you cannot assume that the only difference will be in prepending the J commands with request or edit.
More specifically, the NED uses the tailf:cli-drop-node-name annotation which only applies to C style (hence no vlans keyword).
Create
Recognize Your Peers
Content for Community-Ad
