93
viskansa
Copying NavuContainer from one device to another device using maapi api
Hi Expert,
I have a use case where I need to copy some configuration from source device to target device using maapi and nauv api. I can copy configuration leaf by leaf iterating through the navucontainer but my requirement is to copy the whole container from source to target device in one go. Below is java code which I am using:
  s = new Socket("localhost", Conf.NCS_PORT);
  maapi = new Maapi(s);
  maapi.startUserSession("admin",
                        InetAddress.getLocalHost(),
                        "maapi",
                        new String[] { "admin" },
                        MaapiUserSessionFlag.PROTO_TCP);
  // Start a read transaction towards maapi
  int th   = maapi.startTrans(Conf.DB_RUNNING,
                              Conf.MODE_READ_WRITE);
  NavuContainer ncsContainer = getNcsContainer(maapi, th);
  NavuList devlist = ncsContainer.container(Ncs._devices).list(Ncs._device);
  NavuContainer targetdevice = devlist.elem("pe01.350ecermak.il");
  NavuContainer sourcedevice = devlist.elem("seg1.bglab000ur1.nj.panjde.comcast.net");
  NavuContainer clock=sourcedevice.container("config").container("ios", "clock");
//Now I want to copy clock NavuContainer to target device..?????
   maapi.applyTrans(th,true);
   s.close();
Any idea??
Thanks for help in advance!
Vishesh Kansal
0 REPLIES 0
Create
Recognize Your Peers
Content for Community-Ad
