khgrant
Crypto keyring order issue -- ASR1k
Friends,
I”m facing some challenges with order of commands for a service on ASR1k.
The error I get is
<ERROR> 23-Sep-2015::02:19:01.844 NedWorker Ned-Worker-Thread-0: - NedWorker error for ned_prepare_cli
com.tailf.packages.ned.ios.IOSNedCli$ExtendedApplyException: keyring MPN991:
% No such keyring MPN991
at com.tailf.packages.ned.ios.IOSNedCli.print_line_wait(IOSNedCli.java:885)
at com.tailf.packages.ned.ios.IOSNedCli.applyConfig(IOSNedCli.java:1151)
at com.tailf.ned.NedCliBaseTemplate.prepare(NedCliBaseTemplate.java:476)
at com.tailf.ned.NedWorker.dorun(NedWorker.java:1381)
at com.tailf.ned.NedWorker.run(NedWorker.java:255)
My template does create the Crypto Keyring and then use it in the profile.
I tried dividing the creation and use of keyring in separate templates too, but, no luck.
I suspect that the second section (isakmp) is being added to the device before creation of keyring.
When I comment the keyring in isakmp profile, crypto keyring is created correctly.
Appreciate your help.
—————— Template ——————
<crypto xmlns="urn:ios">
<keyring>                         <———————— Creation of Keyring
<name>MPN{$CUST-ID}</name>
<vrf>MPN{$CUST-ID}</vrf>
<pre-shared-key>
<address>
<address>{$TUNNEL-DEST}</address>
<key>
<secret>{$PASSPHRASE}</secret>
</key>
</address>
</pre-shared-key>
</keyring>
<isakmp>
<profile>
<keyring>                     <————— use of keyring in profile
</keyring>
<match>
<identity>
<address>
<ipv4>
<mask>255.255.255.255</mask>
</ipv4>
</address>
</identity>
</match>
<local-address>
<interface>
<Loopback>6{$CUST-ID}</Loopback>
<!-- <Loopback>0</Loopback> -->
</interface>
</local-address>
<keepalive>
<seconds>10</seconds>
<retry>2</retry>
</keepalive>
</profile>
</isakmp>
</crypto>
1 ACCEPTED SOLUTION
khgrant
Hi Sandeep,
If you look at the IOS ned yang. The dependancy is not there.
        // crypto isakmp profile * / keyring *
        list keyring {
          tailf:info "Specify keyring to use";
          tailf:cli-suppress-mode;
          tailf:cli-delete-when-empty;
          key name;
          leaf name {
            type union {
              type enumeration {
                enum "default" {
                  tailf:info "Use global keyring";
              type string { <== Suggested change to path
                tailf:info "WORD;;Name of the keyring to use”; <== Suggested change to the path of the keyring name
Please try the changes and see if it works. Compile and reload the packages after changes.
Kalyan
1 REPLY 1
khgrant
Hi Sandeep,
        list keyring {
          key name;
          leaf name {
            type union {
              type enumeration {
                enum "default" {
Kalyan
Content for Community-Ad
