To help speed up download times with the All-in-One VM, the DevNet team moved the file to the signiant download manager. Baed on my experience it is faster than downloading via usual http requests via browser or command line download tool. To use it,...
Found below two states show in the NSO and now all configuration changes to the devices are failed. Any doc to explain what is badconfig and how to fix that?state oper-state disabled and state oper-state-error-tag badconfig
Hi experts,Got a quick question about NSO https. I'm using version 4.1 on a CentOS and generate my own key and cert using the below commands:openssl genrsa -out host.key 2048openssl req -new -key host.key -out host.csropenssl x509 -req -days 365 -in ...
The Security essentials 5.4.3.4 Lab "Use Wireshark to compare Telnet and SSH traffic" indicates, that an ova needs to be downloaded. The ova is called "CSE-LABVM"Is it true that this is the same ova as the "Ubuntu_CyberEss"?Or is this a different ova...
Hi, I am trying to do system install NSO 5.2.1.2 on Redhat Server. It was an offline server. so I did installed java and ant rpms manually and installed NSO. I can do ssh to nso cli, but I can not see ports opening up for webui. I have only the bel...
I seem to be in a loop here – I wanted to look at netconf using the netconf console and I installed python paramiko but netconf console is still complaining: gmp@lattice:~/ncs-staros$ netconf-console --hello You must install the python ssh impleme...
Hello Experts, Is there any limit to the number of sessions for NSO Northbound REST API? I know we don't hit the limit in the real world, but my customer would like to confirm. Any comments would be appreciated. Best regards,Hiro
Hello, I am trying to send a 'show version' command to my Cisco ASA using Ansible, but I am encountering the following errors and I don't know why. The same thing works for my Cisco router though. Below are some details that might be helpful. Cisco A...
Hi Team,We're currently searching for the possibility of embedding speed dial feature in Cisco Jabber for Windows.We tried using Custom Tab but had difficulty making it work.Thanks so much!Michael
Hello experts, I have a quick question. My customer is using NCS version 3.4.3. When two transactions (service creation, service modification) occur and there is no relationship between two transactions, does one transaction wait fo...
Hi team, I would like to ask you if there is a best practice recommendation available for netconf-yang agent configuration on IOS-XR nodes in regards to rate-limit and number of sessions. RP/0/RSP0/CPU0:ASR9001-1(config)#netconf-yang agent ...
This document was generated from CDN thread Created by: John Devavaram on 04-09-2012 10:04:27 PM Hello team, We are seeing the following error message on CIMC main page: Overall Server Status is reported as "Severe Fault". Fault Sensors display the f...
Hi, I want to run a jsonrpc command to get the live-status of device hostname. I'm trying the below command but couldn't get succeed. Can any one help me to fix this ? Assume i got logged in and get_trans method ran successfully before executing this...
Hi,I see from the documentation that creating different run-time directory I can run different instance of NCS.Which parameter should I configure to avoid the 2 different instance to be in conflict.RegardsRaffo
