I am developing a service package, which involves creation of a Virtual Router and pushing configs to that device.
I am able to create the Virtual device and add it to NCS using MAAPI.
But, when the NCS tries to do any of check-sync/sync-from/connect, the service package deployment gets hung forever.
When the deployment is hung, I have verified that the device is reachable and I am able to login to device from a different terminal.
And I have also been able to do check-sync/sync-from/connect operations successfully from the NCS CLI(Not when the deployment is hung).
I understand I have not shared much info here.
But, I am hoping that somebody might have run into this issue earlier,
And found out a logical fix to their program which might be a standard way of implementation.
I have used RFM. Didn’t mention that in my previous email.
The main service package issues VM related commands,
And only proceeds to apply configs once the VMs are up, added and synced to NCS.
The event handling is implemented in an Application component.
In this program, when I get VM_ALIVE,
I add the device to NCS – (successful).
Immediately after that, I try to sync the device.
But, this sync operation gets hung, does not return until I manually kill the java VM.
The program flow is something like this,
Init() {
// has subscribed to netconf notifications from ESC
// calls handler_function()
Handler_function() {
If (VM_ALIVE) {
Th = maapi.startTrans(Conf.DB_RUNNING, Conf.MODE_READ_WRITE);
addDevicetoNCS(device_name, ip);
maapi.applyTrans(th, false);
maapi.finishTrans(th);
sync_device(maapi, device_name); // This is where it gets stuck.
