69
khgrant
direct device vs. device template configuration differences
Hi Team,
We have noticed that when we configure, using the NCS CLI,  configuration directly towards the device how the NCS CLI presents the NED configuration options is different.  Is this normal?  In many cases direct configuration of the device is feasible, but when we try the same within a device template the configuration towards the device is rendered by fastmap incorrectly.  Below is an examples showing how the direct device configuration differs from device template configuration.
Thanks, Julie Ann and Phathu
Example 1:
Here is the option of configuring CARD on a template:
admin@ncs(config)# devices template oam-test config
Possible completions:
<slot:string>  3  4  5  6  range
admin@ncs(config-config)# staros:card 3 ?
  link-aggregation mode  redundant  <cr>
admin@ncs(config-staros:card-3)# ?
  link-aggregation
  mode
  redundant
  commit Commit current set of changes
  describe Display transparent command information
  exit Exit from current mode
  help Provide help information
  no Negate a command or set its defaults
  pwd Display current mode path
  rload Load configuration from an ASCII file relative to current location
  top Exit to top level and optionally run command
admin@ncs(config-staros:card-3)# mode ?
<string>[true]
Here is the config when going directly to a device - note that we get the correct choices of active/standby.
admin@ncs(config)# devices device VPC-DI config staros:card 3
  link-aggregation
  mode
  redundant
  [active]  active  standby
1 ACCEPTED SOLUTION
khgrant
jconnary wrote:
Hi Team,
Yes this is normal.
When a YANG model for a device is compiled for NCS three different subtrees will be produced from the original YANG file (see packages/*/src/ncsc-out/modules/yang/*.yang of any package). Each one of the three resulting subtrees will be augmented into different positions in the configuration tree.
The most obvious is the one which is augmented under /devices/device/config which holds the actual configuration. The second one is augmented under /devices/device/live-status and contains besides the config elements the "config false" elements. The third subtree is  augmented /devices/template/config aka. device template.
The subtree of the device template has been totally rewritten for example all mandatory keywords has been removed as all constrains on input values. Now to the answer to the question: all datatypes has been changed to string. This is to make it possible to enter XPATH expressions as the value of an element. If a value consists of curly brackets the expression within the will be treated as an XPATH expression and the result of that expression will be used when the template is applied. See examples.ncs/getting-started/developing-with-ncs/12-templates. Because the datatype is rewritten to string no TAB completion is avaiable in the CLI.
Cheers
/Dag
1 REPLY 1
khgrant
jconnary wrote:
Hi Team,
Yes this is normal.
Cheers
/Dag
Create
Recognize Your Peers
Content for Community-Ad
