khgrant
Dynamically extending VNFR with additional parameters to ESC
Hey Team,
As per NFVO documentation section “setting additional parameters using device templates”, VNFR XML file can be extended with esc-device-template in case ESC’s behavior needs to be further controller e.g. placement, recovery, scripts.
So far I have basic vnfr template (vrouter-vnfr.xml) that includes nfvo/nfvr and kickers. The variables are applied on this template in python code with “self.template.apply('vrouter-vnfr', vars)”.
If I wanted to add esc-device-template, should I modify the vrouter-vnfr template? I was hoping that I can apply esc-device-templates incrementally, as per the service model input values. I tried with the following code:
self.template.apply('esc-placement', vars)
However I don’t see in the final vnfr any changes defined in ‘esc-placement’ template file…
Could you help me to understand the right way to control this?
6 REPLIES 6
khgrant
Kali,
It's very hard to see what's wrong w/o your templates...
Fredrik
khgrant
Hi Fredrik.
in general it is possible to dynamically add esc device settings that are part of vnfr correct? by dynamically i mean that i have  vnfr file and i have several other templates that are merged with vnfr before sending over to esc. so far so good?
would you have python example of how to achieve that?
otherwise i can send my vrouter package if you want me to.
thanks for help
kali
khgrant
Hi Kali,
To use device templates, you should apply device templates before applying vnfr configuration. For example, you can load xml as day 0 configuration.
And, you should add template name(i.e. scale-out) to /nfvo/vnfr/esc/vnf-deployment/vnfr/vdu/esc-device-template in your vnfr xml file.
Best Regards,
Yoshitaka
khgrant
Hi!
> On 28 nov. 2016, at 15:46, Arkadiusz Kaliwoda (akaliwod) <akaliwod@cisco.com> wrote:
> Hi Fredrik.
Yes, absolutely and you should be able to do what you did below, so I suspect something is amiss in the templates.
commit | debug template
- or -
commit | debug service
might help you.
Fredrik
khgrant
We use a template that we load into the tree via load-merge.
  1. 1. load merge a template with values:
<devices xmlns="http://tail-f.com/ns/ncs">
<template tags="merge">
<name>Placement_template_SI</name>
<config>
<esc_datamodel xmlns="http://www.cisco.com/esc/esc">
<tenants>
<tenant tags="nocreate">
<name>mano</name>
<deployments>
<deployment tags="merge">
<name>VPC-SI-N42-MANO</name>
<vm_group>
<name>SI-19.2</name>
                                                <placement>
        <type>zone_host</type>
        <enforcement>strict</enforcement>
        <zone>mano-1</zone>
                                                </placement>
</vm_group>
</deployment>
</deployments>
</tenant>
</tenants>
</esc_datamodel>
</config>
</template>
</devices>
  1. 2. load merge a template with variables that your java/python program provides the values:
<name>Placement_template</name>
<config>
<tenants>
              <name>{$TENANT}</name>
<deployments>
<name>{$DEPLOYMENT_NAME}</name>
<vm_group>
<name>{$VDU}</name>
<placement>
                       <type>{$PLACEMENT_TYPE}</type>
<enforcement>{$PLACEMENT_ENFORCEMENT}</enforcement>
<zone>{$PLACEMENT_ZONE}</zone>
</placement>
</vm_group>
</deployment>
</deployments>
</tenant>
</tenants>
</esc_datamodel>
</config>
</template>
</devices>
khgrant
Hi Kali,
I have used two kind of ESC template in my lab tests. There are classic NSO ESC device templates:
gabszabo@ncs# show running-config devices template
devices template esc-security-group
config
  esc:esc_datamodel tenants tenant {$TENANT}
   deployments deployment {$DEPLOYMENT_NAME}
    vm_group {$VDU}
     interfaces interface {$NIC}
      security_groups security_group [ "{$SEC_GROUP}" ]
devices template esc-vPTA-scaling
config
    vm_group {$VDU}
     kpi_data kpi VM_OVERLOADED
      metric_value 10
      metric_cond GT
      metric_type UINT32
      metric_occurrences_true 1
      metric_occurrences_false 1
      metric_collector type SUBSCRIBER_SESSION
      metric_collector nicid 0
      metric_collector poll_frequency 15
      metric_collector polling_unit seconds
      metric_collector continuous_alarm false
     kpi_data kpi VM_UNDERLOADED
      metric_value 1
      metric_cond LT
      metric_type UINT32
     rules admin_rules rule VM_OVERLOADED
      action [ "ALWAYS log" "TRUE servicescaleup.sh" ]
     rules admin_rules rule VM_UNDERLOADED
      action [ "ALWAYS log" "TRUE servicescaledown.sh" ]
I have referenced to the templates and filled the variables in the vnfr block:
nfvo vnfr esc vnf-deployment vBNG-tenant vBNG-demonstration budlab-esc
vnfr vPTA
  vnfd-flavor basic
  instantiation-level basic
  vdu vPTA
   managed
   image-name CSR-3.16.3S
   flavor-name csr.small
   bootup-time 300
   recovery-wait-time 120
   day0 iosxe_config.txt
    url http://10.62.44.58/nfvo/csr_vPTA_config_template.txt
    variable HOSTNAME
     value [ vPTA0 vPTA1 vPTA2 vPTA3 ]
   authgroup          vBNG-authgroup
   internal-connection-point vPTA-mgmt-int
    connection-point-address start 10.1.2.31
    connection-point-address end 10.1.2.34
   ! first
   esc-device-template esc-security-group
variable DEPLOYMENT_NAME
value vBNG-demonstration
variable NIC
value 0
variable SEC_GROUP
value all-in
variable TENANT
value vBNG-tenant
variable VDU
value vPTA
esc-device-template esc-vPTA-scaling
variable TENANT
value vBNG-tenant
variable VDU
value vPTA
I haven’t developed services for NFVO yet so I used this templates via CLI.
Hope it helps.
Gabor
Content for Community-Ad
