bfung
Erros when run Makefile for IOx SDK sample "app-00"
Already source iox_sdk_env
cd to apps/app-00
make Makefile executable
when run Makefile, there are lots of errors.
Do we need to do anything before running the Makefile?
3 REPLIES 3
Steve Zhang
Hi Billy,
Please try to check the error information. There is some information to figure out what exact problem it is.
Or, can you share the error log so that we can understand it better?
Steve
chuli2
Hi Chun-Hoi,
Did you install all the dependency?
Here is the link of the cookbook in case you didn't have it. 819-IOx-SDK-Cookbook.docx
Or, as Steve suggested, please post your errors so we can help you.
Chun
bfung
Now I know what did I do wrong. I did not do the “source iox-sdk-env” command in the iox sdk install directory.
Now problem fixed.
Thanks a lot.
Billy
Create
Recognize Your Peers
Content for Community-Ad
