khgrant
ESC NED
I loaded ESC 2.1 and ESC NED:
packages package esc
package-version 1.0
description     "netconf package for ESC"
ncs-min-version [ 4.0.2 4.1 ]
directory       ./state/packages-in-use/1/esc
component esc
  ned netconf
  ned device vendor Cisco
build-info date "2016-02-03 10:57:09"
build-info file ncs-4.1.1.1-esc-1.0.tar.gz
build-info arch linux.x86_64
build-info java "compiled Java class data, version 50.0 (Java 1.6)"
build-info package name esc
build-info package version 1.0
build-info package ref 1.0
build-info package sha1 ae425cc
build-info ncs version 4.1.1.1
build-info ncs sha1 ""
build-info dev-support version 1.0
build-info dev-support branch master
build-info dev-support sha1 1812a32
oper-status up
admin@ncs#
But I get the following:
admin@ncs(config)# *** ALARM revision-error: YANG module 'esc_volume' has an unsupported revision 2015-11-18, Ncs supports 2014-06-23. YANG module 'esc_types' has an unsupported revision 2015-11-05, Ncs supports 2015-07-30. YANG module 'esc_policies' has an unsupported revision 2015-09-21, Ncs supports 2015-08-31. YANG module 'esc_opdata_tenant' has an unsupported revision 2015-11-18, Ncs supports 2014-08-06. YANG module 'esc_opdata_interface' has an unsupported revision 2015-11-09, Ncs supports 2015-07-02. YANG module 'esc_network' has an unsupported revision 2015-12-02, Ncs supports 2015-08-05. YANG module 'esc_interface' has an unsupported revision 2015-10-23, Ncs supports 2015-07-20. YANG module 'esc_datamodel' has an unsupported revision 2015-11-09, Ncs supports 2015-07-14.
admin@ncs(config)#
I believe I can build my own ned from the ESC yang files. Where do I find those on my ESC box?
1 ACCEPTED SOLUTION
khgrant
Hi Julie,
You can find them under
/opt/cisco/esc/esc-confd/YANGmodels-tailf
Elie
1 REPLY 1
khgrant
Hi Julie,
Elie
Content for Community-Ad
