Highlighted
FortiNet NED and FortiGate VM (VNF)
Has anyone had success in managing FortiNet’s FortiGate VM (VNF) through our FortiNet NED? I’m working with the FortiGate VM to be able to demonstrate Mercury, ESC, & NSO as part of a complete NFVi solution that includes 3rd party VNFs.
I’ve run into an issue with NSO on-boarding where the NED will connect to the device, run some commands, but then fails and exits. This is ultimately for a customer POC, but is currently limited to an internal Cisco lab until this can be resolved and tested.
Has anyone experienced the same and/or would be able to help determine why the NED is failing and what the best action plan is for resolution?
Here are some specifics, including the NED trace:
admin@ncs> show packages package package-version
                  PACKAGE
NAME              VERSION
cisco-ios         3.0
esc               1.0
fortinet-fortios  3.2.30
tailf-nfvo        1.1
tailf-nfvo-esc    1.1
[root@nso ~]# ncs --version
4.2
[root@nso logs]# cat ned-fortinet-fortios-VMS_FGVM-2_FortiGate_VNFD_3_ports_FG-VM64_esc0_1.trace
>> 8-Nov-2016::21:40:05.179 CLI CONNECT to VMS_FGVM-2_FortiGate_VNFD_3_ports_FG-VM64_esc0_1-192.168.0.27:22 as admin (Trace=true)
  *** output 8-Nov-2016::21:40:05.196 ***
-- SSH connecting to host: 192.168.0.27:22 --
-- SSH initializing session --
  *** input 8-Nov-2016::21:40:05.447 ***
FGVM #
  *** output 8-Nov-2016::21:40:05.448 ***
-- NCS VERSION: 62 6020100 --
-- NED VERSION: fortinet-fortios 3.2.30 2016-10-21 --
get system status
  *** input 8-Nov-2016::21:40:05.472 ***
get system status
Version: FortiOS-VM64-KVM v5.4.2,build1100,161101 (GA)
Virus-DB: 1.00123(2015-12-11 13:18)
Extended DB: 1.00000(2012-10-17 15:46)
Extreme DB: 1.00000(2012-10-17 15:47)
IPS-DB: 6.00741(2015-12-01 02:30)
IPS-ETDB: 0.00000(2001-01-01 00:00)
Serial-Number: FOSVM1YPXDZ4I092
IPS Malicious URL Database: 1.00001(2015-01-01 01:01)
Botnet DB: 1.00000(2012-05-28 22:51)
VM Resources: 2 CPU, 3859 MB RAM
BIOS version: 04000002
Log hard disk: Not available
Hostname: FGVM
Operation Mode: NAT
Current virtual domain: root
Max number of virtual domains: 1
Virtual domains status: 1 in NAT mode, 0 in TP mode
Virtual domain configuration: disable
FIPS-CC mode: disable
Current HA mode: standalone
Branch point: 1100
Release Version Information: GA
FortiOS x86-64: Yes
System time: Tue Nov  8 13:40:04 2016
FGVM #
  *** output 8-Nov-2016::21:40:05.472 ***
-- VDOM disabled --
config system console
FGVM (console) #
set output standard
  *** input 8-Nov-2016::21:40:05.473 ***
set output standard
FGVM (console) #
  *** output 8-Nov-2016::21:40:05.474 ***
  *** input 8-Nov-2016::21:40:05.480 ***
set      Modify value.
unset    Set to default value.
get      Get dynamic and system information.
show     Show configuration.
abort    End and discard last config.
end      End and save last config.
FGVM (console) #
  *** output 8-Nov-2016::21:40:05.481 ***
end
  *** input 8-Nov-2016::21:40:05.482 ***
end
FGVM #
  *** output 8-Nov-2016::21:40:05.482 ***
  *** input 8-Nov-2016::21:40:05.485 ***
config      Configure object.
diagnose    Diagnose facility.
execute     Execute static commands.
exit        Exit the CLI.
FGVM #
<< 8-Nov-2016::21:40:05.485 ERROR: Network Element Driver error econnrefused for device VMS_FGVM-2_FortiGate_VNFD_3_ports_FG-VM64_esc0_1: ned_connect_cli unknown device
[root@nso logs]#
-Corey
5 REPLIES 5
Highlighted
Are you connected via Console port? If so, please try to use IP management port.
Roque
Highlighted
This is a virtual machine and not a physical appliance - connection is via SSH to the management port
Highlighted
Ok. No idea but you could try to re-create the commands the NED sends into the CLI directly and issue a TAC ticket.
Roque
PS: virtual machines also have a console port…typically a TCP connection mapped to openstack server. That is how from ESC you can access a VM console.
Roque Gagliano
Highlighted
Team it is a version support issue in the NED (FortinetNedCli.java).  Not sure of the logistics to get this fixed in the production NED.
/* Verify supported hardware */
            if ( (version.indexOf("FortiGate-200B") >= 0) ||
                 (version.indexOf("FortiGate-3240C") >= 0) ||
                 (version.indexOf("FortiGate-VM64") >= 0) ||
                 (version.indexOf("FortiOS-VM64-KVM") >= 0) ||  <<< I added this and it syncs now.
                 (version.indexOf("FortiGate-1000C") >= 0) ||
                 (version.indexOf("FortiGate-300C") >= 0) ||
                 (version.toLowerCase().indexOf("fortigate-3140b") >= 0) ||
                 (version.toLowerCase().indexOf("fortigate-1000d") >= 0) ||
                 (version.toLowerCase().indexOf("fortigate-3040b") >= 0) ||
                 (version.toLowerCase().indexOf("fortigate-100d") >= 0) ||
                 (version.toLowerCase().indexOf("fortigate-200d") >= 0) ||
                 (version.toLowerCase().indexOf("fortigate-500d") >= 0) ||
                 (version.toLowerCase().indexOf("fortigate-800c") >= 0) ||
                 (version.toLowerCase().indexOf("fortigate-1500d") >= 0) ||
                 (version.toLowerCase().indexOf("fortigate-200a") >= 0) ||
                 (version.toLowerCase().indexOf("fortigate-310b") >= 0)) {
                // found
                LOGGER.info("Logged in");
admin@ncs> request devices sync-from
sync-result {
    device VMS_CSR6_Simple_CSR_VNFD_3_ports_CSR_esc0_1
    result true
sync-result {
    result true
sync-result {
    device esc0
    result true
[ok][2016-11-08 23:10:01]
Highlighted
Hi Brendan,
I can open a ticket on this one for you and get it into the released product.
-Dan
Content for Community-Ad
Cisco Community October 2020 Spotlight Award Winners
