Highlighted
HA setup help
I configured HA as per HA deployment guide and HA is not coming up. Is there a troubleshooting guide or is there something is not right with my configuration/setup? I’m running 3.3 on RHEL7 VM in openstack environment. I can ping between this two VMs and iptable is disabled too.
1 ACCEPTED SOLUTION
Highlighted
Auto start is disabled so HA won't start unless you issue the action from the CLI or set auto start to true.
2 REPLIES 2
Highlighted
Highlighted
Thanks Dan, looking good now.
admin@ncs(config)# ha-cluster auto-start enable admin@ncs(config)# commit Commit complete.
admin@ncs(config)# end
admin@ncs# show ha-cluster members status
NAME                       STATUS
tsoe-nso-master.cisco.com  master
tsoe-nso-slave.cisco.com   slave
Content for Community-Ad
