Hi Expert,
I want to pick up loopback interface number in Java code.
My test code search loopback interface, but I can not pick up interface number of integer value.
I want pick up only “0”,”1”,”2”. How is coding in Java code ?
<My code>
NavuList test1 = managedDevices.elem(customerDevice.valueAsString()).container("config").container("ios","interface").list("Loopback”);
for (NavuContainer loopInterface: test1.elements()){
System.out.println(loopInterface);
// NavuLeaf loopnum = test1.leaf("name”); <— here is error
// System.out.println(loopnum.valueAsString());
<Java debug>
<INFO> 23-3-2016::17:05:44.606 NcsMain JVM-Launcher: - READ SOCKET =>
NavuListEntry[NavuNodeInfo[Loopback,7,2],/ncs:devices/device{vCPE0}/config/ios:interface/Loopback{0}]
NavuListEntry[NavuNodeInfo[Loopback,7,2],/ncs:devices/device{vCPE0}/config/ios:interface/Loopback{1}]
NavuListEntry[NavuNodeInfo[Loopback,7,2],/ncs:devices/device{vCPE0}/config/ios:interface/Loopback{2}]
Please advice for me.
Hideomi
Solved! Go to Solution.
Hideomi,
<My code>
Try NavuLeaf loopnum = loopInterface.leaf("name");
/jan
Hideomi,
<My code>
/jan
You are looping over list elements, but then using list instead of an element. I believe you should do
loopInterface.leaf("name”)
Instead of
BR,
Bostjan
Thanks Jan, Bastjan,
My debug result will be change.
Thanks very much.
/Hideomi
